Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
My bissell is not sucking,its blowing air out the bottom
reddevil6
  • 1673 Answers
SOURCE: Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Posted on Jan 22, 2008
SOURCE: my carpet cleaner
I took my Bissell proheat apart trying to fix the suction in it. I finally realized that the red filter has to not only be cleaned but also opened to get the suction needed for a good cleaning.
Posted on Apr 23, 2008
nwj2468
  • 76 Answers
SOURCE: my bissell want **** up
somewhere on the unit, there will be a round clear cap. when you find it, unscerw it and clean out the inside.
Posted on Mar 01, 2009
  • 190 Answers
SOURCE: the cleaner blows air out of the bottom rather
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Posted on Mar 11, 2010
  • 4088 Answers
SOURCE: it seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Posted on Mar 12, 2010
Testimonial: "it's fixed"
Bissell pro heat carpet cleaner blows out instead of sucking in
Is the full tank flapper (red) closing off the vacuum? Check the screen behind it to see if it's plugged up.
Aug 30, 2016 | Bissell Vacuums
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
The filters are new, the belt is new, I cleaned the hoses but my Bissel seems to blow the dirt out the back onto my feet help
There is probably a clog somewhere. Start by checking the tube where the air is sucked into the vacuum by the brushroll
Mar 15, 2014 | Bissell 3920 Cyclonic Pet Hair Eraser...
My Bissell proheat is not sucking. It's doing the
Hi there! You may want to have a qualified tech at one of our Authorize Service Centers inspect your machine.
Here's a quick link to locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 22, 2013 | Vacuums
It seems to blow air out instead of sucking up
Mar 12, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Bissell 8975 is not sucking up. I took apart the bottom and cleaned it thoroughly and disassembled the filtration system but still it has no suction.
try blowing down the inlet pipe it could be blocked up if you have sucked up some thing big (ei: like the cat or maybe one of the kid's?) some times the fan has started to spin on the drive shaft that would cause it not to **** any more and very soon the motor would start to over heat as well, it may be a better idear to get a new one as the cost of getting it fixed wont be cheep, it would need a new motor fitted, pricy?
Oct 22, 2009 | Bissell 8975 CleanView Bagless Upright...
My bissell 2x steam cleaner is not picking up the water from the carpet. What do I need to do?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vxbv
Jul 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat blowing out air instead of sucking in air
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
148 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
