Question about GE Dishwashers
Whirlpool model shf 5800 will not drain completely
Hello, we have an older model whirlpool dishwasher, model shf 5800/ shu 5000, that will not drain completely. It was working when we first moved in, however it was connected to a garbage disposal that was broken. After my husband replaced the garbage disposal, the dishwasher stopped draining completly. It also is leaking slightly from between the cabinet wall and the dishwasher. Any helpful hints? How's that saying go....fix one thing & another will break?
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Posted on Jun 04, 2008
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Dishwasher doesn't drain completly, I took off drain hose to see if it was plugged. Any other ideas?
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a dishwasher you appear to have a drain cycle concern, however if you could verify the make, i.e. Kenmore, Bosch, Whirlpool etc. And post the model number I'd be better equipped to help without generalizing.
I'll watch for your reply and try and help going forward. Thank you.
Regards,
Macmarkus :)
Jul 17, 2011 | Dishwashers
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher model DU92OQWDBO does not drain water and flapper door for detergent did not open during cycle
My Whirlpool dishwasher stop draining the water.
What do you thing is the problem? Pump?
Thanks, Henry
Jul 01, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher model DU912PFGBO drains very slowly and not anywhere near complete
You may have something obstructing the flow of water through the drain hose. You need a tech to check where the problem is.
http://tclaundryrepair.com/
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher will not drain
Hello Tom,
Glad that you were able to find something out of place in the check valve ( like the gasket) which in turn was restricting the ball in that check valve from being in the right position. I'd be willing to bet that your problem is solved..
Regards,
Rick
Dec 01, 2008 | Whirlpool Dishwashers
Dishwashers Logo
409 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
