Question about Echo Back Pack Blower Flex Pipe 21001308360
Have old Echo leaf blower, model PE 400E.....needs some kind of throttle or adjustment for the choke..also a manual.. got it for $5.00 and motor starts.
chad7houston
  • 62 Answers
SOURCE: Echo PB 400e backpack blower "Adjust"?
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. Not fresh from the gas can, fresh from the pump. And while the gas and oil mixture should be right, it can be off a little bit and still run....but fresh gas is essential! Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 475 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
SOURCE: i have an echo gas powered leaf blower, model
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Posted on Apr 10, 2009
  • 31 Answers
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
Posted on Sep 23, 2009
Need parts for echo pb400
Part # for this filter is ( 13031000760 ).
Oct 16, 2013 | Echo Air Filter For Pb 400e Back Pack...
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
Need oil/gas ratio for Echo back pack lblower - model PB-400E
Since every engine is different the manufacturer almost always has it printed in the gas cap. It should look like 50:1 or 50/1 (50 parts gas to 1 part oil).
Mar 31, 2010 | ECHO, Inc. PB-251C Handheld Blower
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Echo pb 200 leaf blower want start
Apr 06, 2009 | Echo Garden
Loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Mar 30, 2009 | ECHO, Inc. PB-251C Handheld Blower
Hi. Does anyone know what year my Echo pb 400E Backpack blower is?
Sep 25, 2008 | Echo Garden
Echo Back Pack Blower Flex Pipe 21001308360 Logo
89 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
