Question about Maytag Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I press to start. I own a PYE/G4500 IntelliDry. Help. I have tons of laundry
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Posted on Oct 14, 2010
When the timer on an electric dryer fails to start the dryer. Should you still be able to hear it ticking, when the timer is turned on?
Of course. Correct diagnosis is the key to such things. All the items you swapped out were fine. There are checks you can make with all those components. The rotary type timer is just a clock timer like a wind-up alarm clock. When you turn them on, they tick. In normal circumstances, turning it on will start the machine, and not count down. You need to remove it and make sure you have continuity and also power to the timer. There is more to this than meets the eye. The other item that it may be, is the motor itself.
Nov 25, 2017 | Dryers
My Malley 1050S dryer: timer is ticking away but the machine is doing nothing : (
I agree, always cut your losses, dryers are not that expensive. When my home aids break I LOOK To buy new ones now. I figure that once they start breaking they will carry on doing so
Jul 17, 2015 | Dryers
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
Went to push the dial in to start and it won't
first make sure you have power to the dryer.if you have power to the dryer than put your ear to the timer and see if you hear the timer running.if the timer is running than you nead to unplug the dryer and pull the dryer away from the wall so you can remove the vent hose and the back panal and the power cord cover.next look down and to the left and you will see a white plastic thermal fuse.remove the wires from the fuse and use a meter to see if the fuse is closed.if it is not replace the fuse and replace the back and power cord cover.plug the dryer in and check unit out.
Jan 10, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirlpool gold ultimate care II heavy duty gas dryer. When the dial is set on any setting you can hear the motor ticking. When I push the start button I get nothing. Any ideas???
You are probably hearing the timer count down, which means the timer is working right. This sounds more like your start switch is out. If you email or callus with your model number, we'll be sure to get the right parts out to you rigth away so you can get this repaired. We look forward to hearing back from you soon. Hope this answers your question.
Sep 28, 2009 | Whirlpool Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryers Logo
578 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
