Question about Vacuums
GE MOTOR MOD#5KC46GN0050Y HOW DO YOU WIRE IT FOR FORWARD AND REVERSE ROTATION ON 120V?
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
I have a InStyler (the rotating iron) by Tre Milano. This device is for styling hair. This is not a flat iron, but a cylinder that warms up and rotate's against a brush. It has 3 heat settings which...
I'm repairing an Instyler right now.
Troubleshooting, I connected a multimeter and measure the voltage where the motor is connected. When I push the button that makes spin it, I measure 12Vdc which is a correct value for that motor. Then I connected the motor and it did not spin. Therefore I need to buy one motor here:
http://www.makepolo.com/products/Linear-Motor-with-4.5-to-24V-p39074920.html
Same motor... yes you can repair it by installing a new motor.
Feb 04, 2013 | Vacuums
I am borrowing a sewing machine Genie 354 and can not see how to reverse. Please advise?
The reverse stitch is connected to the stitch length function. Reverse stitching usually takes place after adjusting past the smallest possible forward stitch. At no time does the machine motor ever run in a reverse direction. Look for an adjusting lever that controls stitch length.
Aug 18, 2011 | Vacuums
No suction
try to clean the filter of the vaccuum wash it with water.or dispose the dirt inside maybe your vaccum is full of dust. check the suction hose maybe it clog up or check the rotation of the motor maybe it has reverse rotation try to replace capacitor.
Feb 14, 2011 | Vacuums
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Which direction should the brush roller rotate?
take back to repair shop that is most likely the case thank you for useing fixya please rate me
Feb 24, 2009 | Vacuums
Brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Vacuums Logo
90 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
