Question about Westinghouse L2046NV Monitor
I have a problem with my l2046nv monitor. It turns on, flashes and stay dark, you can however see the picture but it's VERY faint (flash light helps). I turned it off and on.. it would turn on and show a picture, but then a second later just go black... the green power button is on and green. I keep turning it on and off..... I do it about 20 times and ... it stays on but it’s still so annoying to do this. Is there a way to fix this problem? Thank you for any help you can provide!
  • Louis Ebert Oct 14, 2010
    julianny, Problem not new!!!! You will need solder wick. solder, soldering iron(pencil) and do some reading in the FIXYA PROFILES of "budmrtn" "buddymc" "12fixlouie" and other monitor tech's here on fixya who already know what's wrong and have repaired hundreds of units with same exact or very similar symptoms. Also visit YOUTUBE for video clips using search terms: "lcd monitor disassembly" and "lcd monitor repair" !!!! At least you were smart enough to use flashlight to determine state of monitor's switch-mode-power-supply! +5v working, +12v in shutdown or very "out of specification. Just do your research! If lucky, you might repair for less than $10 on DIY basis. If this response helpful, rate on fixya for me. 12fixlouie
  • 11,361 Answers
Look for bad caps with leaking/bulging tops or seals first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 14, 2010
A125 monitor is dark
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Toshiba Satellite Computers & Internet
I am not really good with this kind of computer stuff so im going to word this the best i can... i did not buy this new i got it from my brother in- law but after my monitor turns on its fine but getting...
The VGA inputs on these things can be a bit flaky. The DVI inputs work pretty well. I'm going to guess you're using the VGA input, given the problems you're having. There really isn't a fix, as far as I've been able to find.
Jul 07, 2011 | Westinghouse L2046NV Monitor
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
I have a Sony Wega LCD Projection 60wf655. When I turn it on, the red light turned green and blinks green 6 or 8 or 10 times or indefinitely. No picture but after a minute of being on the screen glows...
This could be the "thermal fuse" which usualy is next to the light bulb. Part cost around $5.00. Please check your manual for directions depending on light and times blinking.
Apr 11, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
I turn my L2046NV completely off at night and lately it won't fire up and the green light is flashing?? The first time I simply unplugged the power cord and plugged it back in and it came on......this AM...
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem......
Dec 09, 2010 | Westinghouse L2046NV Monitor
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
Visit www.kodak.com/go/stepbystep
NOTE:
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Moniter flashes on, then goes dark. help please!
Sounds like a cable issue. Since this is a NEC monitor the cable has connectors on both ends. Turn off the monitor disconnect both ends and reconnect, then turn it on.
Jul 02, 2009 | NEC Computers & Internet
My Samsung HD TV 50" progressive Monitor goes off and turns dark
Samsung HDTV will stay on when turned on the temp lamp and timer light are flashing continually. what should I do to eliminate this problem?
Dec 08, 2008 | Televison & Video
No Image on Monitor Westinghouse L2046NV
well i just had this problem this morning i woke up turned on the monitor and it came on but went out. but i soon found out it was not the display that is not coming on its the black light. if you look closely you can see the display but there is no light to light it up so you can see. it doesent seem to be anything wrong with the circuit board just the black light i am going to be taking the monitor apart to see if there is anything me or any of you can do for the monitor to fix it.
Jul 26, 2008 | Westinghouse L2046NV Monitor
Westinghouse L2046NV Monitor Logo
103 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
