Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My ultimate care 2 washer is leaking water. It appears to be coming from somewhere around the pump. It leaks whenever there is water in the tub. it does not have to be running at all. I poured a partial pitcher of water into the tub and it immediately began to leak.
  • 132 Answers
This could be one of 2 thingsyour not on a level surface or the seal has gone south./well i lied here is another therory your out let is not on or has a leak ,set it up a little higher on some bricks and run a short cycle see where its seems to be comeing from.
Posted on Oct 14, 2010
Whirlpool Gold Ultimate Care II washer is leaking oil and water. Water is not leaking from the hose connection but seems to be coming from bottom of washer, as is the oil. Is it dead?
never dead just depends how much time and money you want to spend
new pump $60.00 dollars
new coupling $22.00
new tub seal $15.00
transmission and tub seal $236.00
specialty tool spanner wrench $16.00
this is just parts if you decide to replace installing yourself
Jan 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care 2 is leaking water and not from hoses. Only in use.Is there a easy fix for this?
Check the washer tub gasket seal.. Normally located under the base of the tub. May just need to tighten any bolts that are loose around the gasket if there is one.
Mar 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Our ultimate care II washer is leaking. I'm not
could be the tub seals,fill it up with water,put it on spin and look up where the trainy goes into the tub,if it's leaking there you have to decide if you wanna repair it or get a new washer.also it could be coming out of the pump when it drains,you need to just get in there with a light and check it out,remove the two screws in the back of the top console,the console is on hindges,lift it up and remove the two clips that hold the frame to the back,remove the lid switch wires and pull the frame up and forwards to remove it,now get a piece of wire and stick it in the harness where the lid switch goes,there are three holes plug the piece of wire in the outside holes and this will let you put the washer into spin cycle,look and see where the water is leaking from,could be leaking from the drain hose too but you gotta get in there and look,let me know if you need any more help
Feb 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II washing machine that is leaking water onto the floor. The water is not coming from the back of the machine. What do I need to look for and how do I get into the machine?...
I suspect you may have a drain pump leaking on your washer. The following link explains all the steps necessary to access and/or replace the pump (if required):
http://www.fixya.com/support/r397092-replacing_water_pump
If the leak isn't too bad, allow the tub to fill about 1/3 of the way and turn off and unplug. With the exterior case removed, you should be able to see where the leak is coming from. If the leak is coming from the front of the washer, its probably your drain pump or drain hoses. If the leak is coming from the center under the wash tub, you more than likely have a bad tub seal. If the leak is coming from the side of the wash tub, you probably have a loose air hose on the air dome (with this problem, the washer will begin to leak when the tub gets to about 1/4 full). Also check all your drain hose clamps to ensure they are tight. The only other thing that can cause leaks is a cracked wash tub (not real common).
If you have questions, please let me know. I hope this helps you narrow down your problem.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
