Question about Canon MultiPASS F80 All-In-One InkJet Printer
May be a printer head problem. Every 3rd line or so does not print. I have tried the Menu cleansing--head cleansing without success.
  • jclousson Oct 14, 2010
    I know it is a printer head problem. I want to know whether it can be fixed without installing a new piece of equipment. I have tried the head cleansing.
  • 6,993 Answers
Clean out the nozzles through the printer utility and that should solve the problem.
But if the problem is not solved, then you will have to buy a new print head because it sounds like a print head problem as you guessed.
Good luck.
Posted on Oct 14, 2010
  • Walesarumi
    Walesarumi Oct 14, 2010
    It cannot be fixed without installing a new print head. I just saw this on our comment.
  • 4,472 Answers
First thing I would recommend is to uninstall the printer and reinstall it with the latest drivers available from canon which you can find here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_f80#DriversAndSoftware
Just click on drivers and software if not already on that page and select your operating system.
I would next print a test page and see if that does it as well.
Thank you,
Lee
  • Lee A.
    Lee A. Oct 14, 2010
    In your original post you said "may be" a print head problem. I can only give solutions based off the information given so... If you want to fix this problem and have already tried head cleaning, your next option is replacing it which if you can locate the part should be about 50$.
    Thanks,
    Lee
When I print the pages are clean, but when I make a copy there are vertical lines on the page
hi there is problem with print head yours print head is blocked, there is way to open blocked head if you are technical you should have to remove ink and then you can takeout print head.
there is the way to open blocked head without any coast.
1. remove print head from printer.
2. take your print head in to wash sink.
3. keep upper side down of print head under the water tab & open water for 10 minut.
4. dry water from print head.
5. reset back print head in to printer make copy or just run clean print head from tools.
T.C.
remember me in yours prayers
Sep 22, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
I have a Canon I9950 printer it started playing up and despite head cleaning in warm water etc as recommended still did not print all the colours. I bought a new print head and new canon inks (always used...
I would check to make sure that the contacts on the cartridgew sensors are not fouled with dried ink. A q-tip with rubbing alcohol should help to remove the dried ink if that is in fact the problem.
Oct 19, 2013 | Office Equipment & Supplies
Ink smear on back of print job canon pro 9000
control panel - printers- highlight printer but dont select - top right printer preferences - maintance- clean printer heads etc clean with all options available. should fix the problem.
Feb 10, 2013 | Canon PIXMA Pro9000 Printer
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
My Canon MP240 suddenly began printing streaky lines at regular intervals on the page. In between the print is good. I have done all maintenance functions without success. I think perhaps the roller may be...
Try Pulling the print head out and cleaning it manually
  1. First remove the cartridge
  2. lift the orange or green lever on the side of the cartridge holder and pull the print head out.
  3. Fill a saucer with boiling water, about 2mm deep
  4. Place the head in the boiling water and leave for about 2 mins. Dry before replacing in printer
  5. While the head is out have a look in the printer for any excess ink on the rollers or where the cartridge head "rests". Clean with tissue paper if needed.
  6. Re-assemble the printer, replace the head and cartridges and test.
I hope this helps
Regards GM
Apr 10, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I HAVE A CANON MP 760 PRINTER THE MAGENTA COLOUR LINE IS TWO TONED WITH DARK AND LIGHT PINK . SO WHEN PRINTING PICTURES THERE IS DISTINCT LINES CAN SOMEBODY HELP HAVE TRIED THE CLEANSING REPLACED THE...
You need to conduct the following steps:
Printing the Nozzle Check Pattern
The nozzle check pattern shows if each print head nozzle is operating properly.
You can also print the nozzle check pattern from your computer.
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press <Feed Switch> button to select the paper source.
  3. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  4. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  5. Use left or right arrow to select [Maintenance] and press <OK>.
  6. Use up or down arrow to select [Nozzle Check] and press <OK>.
  7. When prompted to print a nozzle check pattern, use the up arrow to select [Yes] and then press <OK>.
    The machine prints a nozzle check pattern
Print Head Cleaning / Head Refreshing
If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head.
MEMO:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. In either COPY, PHOTO, or FILM menu screen, press <Menu> button.
  2. Press the left or right arrow to select [Maintenance/Settings], then press <OK>.
  3. Use left or right arrow to select [Maintenance] and press <OK>.
  4. Use up or down arrow to select [Print Head Cleaning] or [Head Deep Cleaning] as necessary and then press <OK>.
When prompted to clean the print head, use the up arrow to select [Yes and then press <OK>.
IMPORTANT:
If normal print head cleaning does not improve print quality, perform deep print head cleaning.
Print Head Alignment in Windows
If colors mix or streaks appear in the nozzle check pattern, perform the print head alignment.
The print head alignment can be performed either automatically or manually.
If the automatic print head alignment does not resolve the problem, perform the print head alignment manually.
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
My prints have white horizontal lines, i don't have a manual
You may end up replacing the printhead as well; this, as with most inkjets, don't tolerate longer stand times without printing, the ink solidifies in the tiny jets and 'cleaning' doesn't help.
If you are adventurous and have too little to do, you can try cleaning the printhead using the detailed instructions found here:
Canon Printhead Rescue
I tried it, without success, gaining only little improvement in print quality and after buying two heads purportedly for my 4000 and getting 'Wrong printhead' emssages with both, I did my own research and found that the printheads first bought were in fact NOT for the 4000. I even tried an ultrasonic bath of some power without success. Ordering the right printhead (QY6-0049-00) which I found new on eBay solved the problem.
Feb 03, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MultiPASS F80 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
