Question about Sharp LC-32GA4M 32 in. HDTV-Ready LCD Television
When i power on sharp 32inch lcd it turn of after 40 second light goeas red led
circuitworld
  • 335 Answers
SOURCE: Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Posted on Feb 11, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
budmrtn
  • 11361 Answers
SOURCE: Line only on my screen 32inch 2year old LCD Sharp
Are they vertical lines? It may be bad T-CON board or main logic board, send me pictures if you can.
budmrtn@aol.com
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
  • 517 Answers
SOURCE: My Sharp LCD panel color
Good day!
This are the steps to find and fix that problem.
  1. Open the cover of your TV.
  2. Disconnect the input supply of system board or main board that comes from the power supply unit.
  3. Power ON the TV to check the voltage reading of disconnected connector to the input of system board by using voltmeter.
  4. Check the 5vdc and 12vdc by using voltmeter.If you got voltage reading of 5vdc and 12vdc,try to connect the input connector of the system board and check the voltage again.If no voltage when you connect it.There's a shorted parts on your system board.Replace the whole system board because its very difficult and expensive to repair it.
  5. When the input voltage of system board doesn't have 5vdc and 12vdc even disconnected on the board.The problem is on power supply.
Check the following:
  • Fuse-Check the fuse if busted.
  • Transistor and diode-Check the transistor and diode if shorted.
  • Resistor-Check the resistor if open/change value.
  • Capacitor-Check the capacitor if leak/bulge on top.
If you found the defective parts that mention above.Replace it with the same type and ratings.
NOTE:If the following parts are OK and the problem is still there.The power supply have major problem and its not for D.I.Y..
Thank you and good luck
Posted on Apr 25, 2011
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Nov 03, 2008 | Televison & Video
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Sharp LC-32GA4M 32 in. HDTV-Ready LCD Television Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
