Question about Frigidaire Refrigerators
I want to remove outside electronic ice maker and water dispencer panel to add a wood panel to the door. Then I will re-install electronic unit. How do I remove this panel on outer door?
  • 11,896 Answers
The front panel should just snap off.
If you look under the bottom edge there is often a couple small slots.
Put a flat blade screwdriver in the slot and pop the front off.
  • Turn off the water at the wall. Disconnect the power at the wall.
  • 2
    Disconnect the waterline and wiring harness. Open the door and look near the lower hinge. You should see a tube with collars. That's the water line. Push in on the collars. You should also see an electrical harness. Disconnect it.
  • 3
    Remove any clips.
  • 4
    Pull the waterline and harness through the lower rail.
  • 5
    Close the doors.
  • 6
    Remove the hinge covers if there are any. Grasp the cover on its sides near the back. Push back on the cover and then lift it. Try not to break any retaining tabs.
  • 7
    Remove the hinge. Unscrew the torx screws.
  • 8
    Remove the doors by rotating them to 90 degrees. Don't allow the waterline and electrical harness to be pinched, and lift the door upwards
  • Posted on Oct 14, 2010
    Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
    at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
    Sep 21, 2014 | GE Refrigerators
    Water in door dispencer but no ice cubes in freezer
    Remove the water line in the back of refrigerator going into the ice maker - its likely the line froze. Once thawed (about an hour) put the water line back on and cycle the ice maker - you should hear the water go into the ice maker.
    Dec 17, 2013 | Refrigerators
    No water in ice maker we bought this appliance second hand and installed it this afternoon. There is water in the door dispencer, but not in the ice maker Thank you Johan Kruger
    If you just installed this unit it may take time for the icemaker to start to receive water. The water through the door you had to sit and keep button depressed to clear the air from in the line. The icemaker only calls for water for 7.2 seconds. It usually takes a few cycles before ice maker gets water. Give it 24hrs and see if it helps. Make sure the arm on the icemaker is set to on. Usually pushed down.If you have any questions Please comment me back
    Jul 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
    How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
    1. Disconnect the unit from the electrical
    supply and wait for 3 to 4 hrs to get ice melted.
    2. Pull out and unclip the drip tray on the ice
    and water dispenser compartment.
    3. Remove the screws from the ice and water
    dispenser compartment front panel and
    turn it over. The selector switch pack and
    dispenser switches are now accessible for
    testing.
    Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
    YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
    Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
    Will not dispence ice, crushed or solid cubes, will dispence h2o
    Hi
    If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Please do rate the solution as "FixYa" and revert for further assistance.
    Thanks
    Rylee
    Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
    Icemaker
    Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
    Let me know if this helps.
    Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
    How to clean ice maker door on a Kenmore
    is it a side by side or trio with french doors ? we will asume is a side by side under the dispencer trip there are two small slots were you insert a flat screw driver. now twist to unlock them once you remove that cover you can see more inside and how you can have more access but be care ful disconect unit if possible
    Oct 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    GE 23.5 CU FT side by side w/ice maker and water in the door.
    replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
    Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
    Refrigerator
    it has a bad main control board call maytag they will most likely repair it in warranty for you
    Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
    Refrigerators Logo
    43 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
