Question about Health & Beauty
Potec prk 5000 autorefracter user manual - Health & Beauty
99 GMC Sierra headlights & running lights won't work!
Headlights Circuit Description
The headlights are controlled by the body control module (BCM) via the AHL Relay when the headlamp and panel dimmer switch is the AUTO position. When in the AUTO mode, the BCM receives a signal, (voltage) from the ambient light sensor, based on the voltage of the signal of n the sensor the BCM turns the day time running lamp (DRL) lights OFF and the headlights ON. The headlights can also be turned on by placing the headlamp and panel dimmer switch in the head position.
The relay coil is fed by the headlamp and panel dimmer switch or the BCM and the battery B+ buss bar in the underhood bussed electrical center (UBEC). The BCM supplies current to the relay based on the input from the ambient light sensor via CKT 352.
The relay output feeds the LT HDLP and RT HDLP fuses to supply current to the low and high beam lamps on CKT 1340 and CKT 1240. The ground for both the low and high beam lamps is supplied via CKT 524 and CKT 525 to the dimmer switch. The dimmer switch uses CKT 1850 for a ground to G203.
Some circuits are monitored by the BCM, and upon failure may set a DTC.
Park/Side Marker and Tail Lamps
The park/side marker and tail lamps are split between the following 4 fuses:
The FR PRK
The LR PRK
The RR PRK
The TRL PRK
These fuses receive voltage from the park lamp relay. When the headlamp and panel dimmer switch is in the auto position, the body control module (BCM) controls the relay by grounding CKT 1080 based on the input of the ambient light sensor. The park LPS fuse supplies battery positive voltage (B+) to the relay at all times.
When the headlamp and panel dimmer switch is in the PARK position, the relay is by passed through the INT PRK fuse. Current flows from the PARK LPS fuse through the headlamp and panel dimmer switch to the INT PRK fuse in order to feed the following fuses:
The FR PRK
The LR PRK
The RR PRK
The TRL PRK
Park Lamps Inoperative
Step
Action
Value(s)
Yes
No
  1. Turn the ignition OFF.
  2. Connect a scan tool.
  3. Turn the ignition to the ON position.
  4. Using the scan tool, check for any DTCs in the body control module (BCM).
Does the scan tool show any DTCs ?
Go to Diagnostic System Check - Body Control System in Body Control System
Go to Step 2
  1. Turn the headlamp switch to the park position.
  2. Connect a test lamp from (back probe) terminal B of the headlamp and panel dimmer switch to ground.
Does the test lamp light?
Go to Step 4
Go to Step 3
Locate and repair the open in CKT 240 (ORN) between the switch and the mid bussed electrical center (MBEC).
Is the repair complete?
System OK
Connect a test lamp from (back probe) terminal A of the headlamp and panel dimmer switch to ground.
Go to Step 6
Go to Step 5
5
Replace the headlamp and panel dimmer switch. Refer to Headlamp Switch Replacement .
System OK
6
Connect a test lamp from the INT PRK fuse, located in the left bussed electrical center (LBEC), to ground.
Go to Step 7
Go to Step 8
7
Locate and repair the open in CKT 74 (LT BLU) between the MBEC and the UBEC.
System OK
8
Locate and repair the open in CKT 74 (LT BLU) between the headlamp and the panel dimmer switch and the LBEC.
System OK
Aug 11, 2016 | GMC Sierra Cars & Trucks
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
Using without parking break
Hi James,
Page 27 of the installation manual (http://www.wwstereo.com/_files/155788/documents/Kenwood--Manual.pdf) shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
I need a free manual download for the Dell
There are several manuals for Dell Inspiron 5000, You can download whatever you want from this link;
click here to open the link
Open the link, and from the "Document Title" lists, select the one you would like to download, they are only pdf files.
Or alternatively you can read all the documentation and tutorials here;
Online User Manual Dell Inspiron 5000
Good luck.
Thanks for using FixYa.
Jun 26, 2010 | Dell Inspiron 5000 Notebook
USER MANUAL FOR A KENWOOD DPX 5000 DOUBLE DIN CAR STEREO
hi
i want rest code kenwood dpx 5000 car tape plz reply mee with master rest code
thanksssssssssssss
Mar 08, 2009 | Kenwood Car Audio & Video
Health & Beauty Logo
572 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
