Question about Tomtom GO 910 GPS Receiver
Tomtom 720T charging problem
Basically my Tomtom 730T charge only lasts about 1 hour. I have allowed the device to be on charge overnight, so that is plenty of time, so why is it only lasting about an hour. Help!
  • 868 Answers
Replace the battery
Posted on Jun 02, 2008
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
The Tomtom XXL was unplugged from the cigarette lighter overnight. What do I do to recharge it?
The device can be run from the lighter plug without being charged first. The obvious answer is: plug in the device again; when the car is key is in and electricity switched on, it should charge again.
Most Tomtom devices also come with a standard USB cable or charge cradle with non-standard connector on device end (but USB on the other). It plugs in a PC for use with the Tomtom HOME software and also for charging.
Jan 01, 2011 | Tomtom GO GPS Receiver
Tomtom still charges but traffic receiver stopped working
I'm using the TomTom Go 730T - I think this is the latest and the last TT with Traffic because TT stopped supplying this option. I'm having the same problem from time to time but a reset helps. Just press the Reset button and after restarting the traffic option is back. Janos
Jul 09, 2010 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Why does my tomtom go 730 not function when it is cold and how long should the battery work for
To my experience, battery capacity and life is very poor for the GO 730.
If brand new, the battery can last up to three hours but this degrades quickly. If its cold, the electrochemical process in the battery is slower, adding to the problem.
Also, switching off the TomTom does not really switch off, it goes to standby, still using a little power continuously. After a day or two this completely drains the charge.
I have my GO 730 since mid 2008 and battery is down to ten minutes of use after a full charge. In my car I use the provided car DC adapter, so I do not mind the bad battery too much.
Feb 07, 2010 | Tomtom GO 730T Car GPS Receiver
Go 730 not sending a fm signal
If you have made a recent update this may be the reason you may have lost your FM transmission!!
Tom Tom disabled silent FM transmission on these units to comply with the law in certain countries which prohibit these FM transmissions. Later updates configured the units to output lower strength FM transmissions.
There is a possible workaround for this - see this link for a discussion on the issue.
http://www.tomtomforums.com/tomtom-go-630-720-720t-730-730t-740/19436-go-730-lost-fm-transmission-after-map-update.html
Hope this helps. Thanks for using FixYa
Dec 27, 2009 | Tomtom GO 730 Car GPS Receiver
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl roseden@telus.net
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
TomTom One XL battery not holding charge but a few hours........
You need to change this battery as if it finally collapses it will ruin the internal components
Aug 14, 2009 | Tomtom XL 330 Car GPS Receiver
Tomtom GO 910 GPS Receiver Logo
44 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
