Question about Magellan GPS
My Magellan Roadmate is approx 2.5 yrs old. It will not turn on at all. I have replaced the battery, checked the car charger, do not have a house charger with a mini connector, but borrowed one and--- still nothing. Where can I send this for repair?
  • 6,487 Answers
The best way to have this unit repair is to send it back to Magellan and they can have it fix , to do that contact them via this number so they can provide you the complete details bout the repair 800.707.9971.
Posted on Oct 14, 2010
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
GPS does not come on when I plus it into lighter in car.
This behavious is typical of a bad battery or charger and it can also be a internal hardware error. Usually it just means it is time to replace the battery. The age and the symptoms are typical of a dead battery. They are actually pretty resonable for cost $15-$25. You can replace it yourself if you take care to replace any seals properlly. The battery itself just plugs in like a phone battery. Charge it up overnight and you should be up and running.
If the problem is internal you can send it in to Magellan support and they should be able to fix or refurbish it.
Apr 01, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
Sep 10, 2009 | Magellan RoadMate 1200 GPS Receiver
Magellan Roadmate 1200 won't lock onto any satellites. Satellite tracking is zero. Worked two days perfectly, day three, nothing. Brisco
check that your battery is fully charged use an AC charger if you have one.
Check Baud rate and port are set in accordance with manual
Jul 26, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan roadmate 1412
Try the reset button on the side above the plug in.
Jan 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan GPS RoadMate 4250 Will Not Hold Charge
Send it back to the manufacturer under warranty for repair/replacement.
Mar 26, 2017 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 2000 doesn't power up
try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
Jun 07, 2008 | Magellan RoadMate 2000 GPS Receiver
GPS freezes when I need it to work!
i have a 800 also but it does not freeze because i make sure it is up to date on all firmware and software,if i was you chk out for updates on the magellan website2.gif after you register your unit then if ther is, which i know do the update and you will have no problems after that.let me know how it goes.
Dec 25, 2007 | Magellan RoadMate 800 GPS Receiver
GPS Logo
275 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
