Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
What if after you press the reset button, wait 30 seconds, disconnect DSL modem and disconnect router and restart everything (several times) and it still doesn't work. It was working fine before we pressed the reset button but we didn't have a password, which is why we reset to default settings.
  • 2,263 Answers
When you reset the router, it comes back to factory default settings. Now you will need to reconfigure the router for the Internet connection.
If you have the CD then try to run the CD.
Or you can reconfigure the router without the CD also.
Click Here for step by step solution
Posted on Oct 14, 2010
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Jul 19, 2011 | Cnet CWR-854 Router
I nee to syn this router with my cpu. what do i do.
Belkin reset:
1. Locate the reset hole on the router. The button will be on the back or side of the router.
Leave the router powered on.
  1. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  1. Remove the paperclip.
4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 12, 2011 | Belkin F5D8236-4 Router
Followed the disk guide, everything goes well then i get a error 111. done it 4 times and get the same error. whats up
Reset the router:
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
Then:
. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | D-Link (DI-711) Router
My router cant connect to the internet.
Did you try a factory reset?
With the router powered on and running, se a toothpick or something like that to hold the reset button down for 20 seconds. Release the reset button and wait for the router to reboot. This usually takes a minute or two.
You may need to reboot your computer, although it's generally simpler to unplug the ethernet cable from the router (after the factory reset), wait 30 seconds, then plug the cable back in.
This is also known as 'renew dhcp lease'.
If that doesn't work, try powering down your cable modem/dsl adapter, power down the router, then power up the cable modem/dsl, wait for it to connect, then power up the router.
Some cable modems and dsl boxes 'lock on' to the first ethernet adapter they see, this will make the cable/dsl box reset the lock.
Aug 29, 2010 | D-Link AirPlus DI-524 Wireless Router
When I hook up my Dell2350 router to my westell dsl modem i can not access internet with my desk top or my laptop. When i disconnect the router I can access internet through dsl for desktop with no...
You will need to check the settings of the router. You are able to go online when you connect the computer directly to the modem. Your internet service provider is DSL. You can try to reconfigure the router. Press the reset button on the router for 30 seconds. release it. unplug the power to the router. plug it back in. wait for 1 minute and try to reconfigure the router. Click Here for step by step set up
Nov 18, 2009 | Computers & Internet
There's no output signal on my router when i connect my modem to it and the out is to my PC, it says no network connection
Connect the Cable modem to the router's Internet/WAN port, then connect the PC to any one of the router's ports.
Reset the D-Link router:
D-Link Router reset
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. Then:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 23, 2009 | D-Link AirPlus DI-524 Wireless Router
Wont connect to internet
Note: Do not recycle power during the reset procedure. The default user name for most Belkin devices is blank and the password is Admin.
then:
Let me know the results.
Thanks, Joe
Apr 17, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hey, i'm having trouble setting my MSI wireless router
Make sure the physical connection is correct.
- Cable/DSL Modem > connected to Internet Port of the router.
- Computer connected to port 1 on the router
First, try to reset the router. Press the reset button at the back of the router for 20 seconds, then unplug the power to the router and the modem. Wait for 30 seconds, power on modem first, wait for the lights to go solid, then power on router.
That should be all set. If not, please run the Setup CD that came with your router.
Dec 03, 2008 | MSI (MS6848) Wireless Router
Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
Oct 18, 2008 | Linksys BEFW11S4 802.11b Wireless...
Install wirelss router
not wireless if it's the BEFSR41
Feb 23, 2008 | Linksys EtherFast Cable/DSL Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
104 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
