Question about Makita Saws
The saw is hard to move to the angled positions. You have to really pull on it to get it move
I used a power saw every day for years. Makita is a good brand. We used Milwalkee and Craftsman. My Milwalkee, I used the side of my hand to hit it into place >> I didn't hit it real hard, but the angle setting should move a bit sluggish so you can get to the correct cutting degree using one hand while holding saw in other hand. If the angle setting is floppy loose, you have to use two hands to get it set.
The whole guide assembly should come loose from the motor part. Take it apart. Remove the dust & dirt. Spray a bit of WD-40. It should be good to go. Remember the saw is your friend so cut straight and fast.
Up-vote if this helped. Thanks for the feedback.
Posted on Oct 15, 2010
I have a black and decker jigsaw that the plate you put on the wood moves and the cut angled and I do not it to?
Hi John:
These saws are usually really reliable, and SOLID.
I'd suggest that you UNPLUG THE SAW and then explore a bit. Look for loose bolts at the pivot points, or possibly a poorly fitted bolt. If this is your saw that you have had for some time, you should know what maintenance has been done that possibly caused this problem.
Oct 03, 2015 | Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
How do I adjust the worm gear on my table saw?
I believe that that model of Powermatic has a lock for the blade angle that also extends and retracts the casters for moving the saw. You may have unlock or change the handle position to allow for blade angle adjustment. You can get a manual or information at the Powermatic website to show you how to change the settings on the saw. Hope that helps.
May 28, 2014 | Powermatic Saws
Can't rotate Blade Angle for Craftsman Radial Arm Saw 113.23100.
The manual writer may have confused knobs or may have used different terminology to identify the same part. A call to Sears might clarify this issue, but then again maybe not. Check operation of all apparent knobs and you may locate the correct ones.
Dec 03, 2013 | Craftsman Sears Radial Arm Saw Owners...
Ryobi mitre saw - saw dust has collected inside base making it extremely hard to move the saw angle horizontally.
Flip the saw upside down ,and loosen the bolt on the bottom. Now blow the sawdust out.
Sep 18, 2011 | Ryobi Garden
Have a brand new husqvarna 445 that I can't start. Followed instructions but nothing happens. Also, the Guide says to "Press Decomp button down fully" The thing doesn't move up or...
Hi, we had a Husky just like yours, I never used the decompression button and it started on three pulls all the time. Squeeze the trigger lock, then let it go and the carb is automatically set for startup. Pull the choke and the red on/off button automatically goes to "on". Crank till the saw fires about 10 seconds and then push the choke in slow untill she takes full 12,000 rpm revs. On Youtube "The Chainsaw Guy" has a good video on Youtube showing the 455 Rancher startup:
(The chainsaw guy shop talk Husqvarna 455 rancher chainsaw 9 22)
If you move the saw from a very cold shed into the sun and start it at -20 Celcius it will ice up the gas in the carb so you have to set it on the truck hood for 15 minutes to equilize the aluminum casting temperature with the air temperature. The pop up valve looks like it will pop back up when the saw starts. If it sat for months with the pop button depressed, that might cause it to rust open, then you would never reach this saws 12,000 rpm. You might try unscrewwing the pop up valve and derusting it in TSP solution for 20 minutes to get the rust out of the valve and make sure the spring inside the valve is OK, it may be just a detent kind of temporary hold-down. Screw it back in and then I would just leave it up when starting! Always file the teeth in the most comfortable position for you with the round file in the middle of the bar's length and moving toward the engine and just under the top of the flat tooth but not cutting the rivits - use only forward cutting of the file and about 50 degrees of angle saves cutter material a lot more than 35 degrees which is too sharp and weak for hard knots and sand stuck in the wood. 15 minutes work on the left angled and then the right angled teeth will make it just fall through the wood about 7 times faster than the Youtube video shows in his outside cutting test, so you can save loads of hours by becoming a good filer - my Dad did that in a sawmill for decades. Also be a little more carefull with the saw than the video shows, the tank metal is very fragile under the saw and even starting it on a rocky surface with your foot braced into the handle will wear the aluminum out underneath due to vibration against sharp granite edges.
Jun 02, 2011 | Husqvarna Garden
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
Reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
May 16, 2009 | Bosch RS15 1 1/4 Reciprocating Saw
Saws Logo
87 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
