Question about Amana Haier AP125HD Air Conditioner
Amana AP125HD Portable Air Conditioner This unit now seems to randomly shut itself off, beeping 4 or 5 times after doing so. Not on a timer. I can restart it immediately, but will shut off again in an hour. Why? How do I fix?
  • CCGardenlady Jun 28, 2008
    My Ac went off and I am wondering why I have emptyied the tankand it started again but the power went right out inthe circuit breasker unit si I turned it on and the unit did not come back on and I let it rest and am wating to see what to d now it is hot and I need the AC to operate! but??? ikt resets and nopthing! why is this?
I have this Amana/Haier unit. I recommend reading the Owner's Manual because it actually discusses this issue although a bit indirectly. I've used the unit in Mississippi, and it's voltage and surge sensitive, and the Manual implies.
So, when the Manual says to put the unit on its own circuit, and to make certain that the circuit is also fully capable of supporting the electrical load, including the full amp load noted, it means it, in my experience. I even had to ditch a work-around long extension cord (albeit a heavy-duty, rated one).
The long term solution was making sure the machine was getting clean, non surging, non sagging AC power on its own circuit to the main board. And then ... it's worked flawlessly in heating, cooling, drying and ventilation modes.
One last thing ... the Manual is also serious about leaving the unit to sit still for 12-24 hours if it moved and rotated from the vertical. If fhe oil moves inside and can't resettle, it can also trigger motor shutoffs.
I hope this is helpful for enjoying what seems to be a well built machine.
Posted on Feb 23, 2009
My AP125HD had exactly the same symptoms. It did not matter what ac outlet I used where the air conditioner was.
But...THIS PROBLEM STOPPED once I moved the ac cord to an outlet outside of the house. This outlet is on it's own separate circuit breaker and I have no other electrical equipment/appliances on it.
I guess the user manual is correct that this unit should be on a home circuit all by itself!
Posted on Jul 03, 2008
I dont have this one, but I searched for problems because I am thinking of buying one. Thanks for info above. This unit has a very high capacity, and a very high electrical load to match. Understandable that it needs full capacity 15 amp service.
Posted on Apr 10, 2009
I am not able turn the unit on
First check the circuit breakers then the outlet that the unit is plugged into.
Good luck,
Marty
Jun 20, 2014 | Amana Haier AP125HD Air Conditioner
I purchased a Haier Amana commercial cool portable air conditioner tonight and there seems to be something missing. There is a little hole in the rear of the unit that is discharging water, there is no...
Since there are no specific numbers for your equipment, I will respond generically. Part of the cooling process is removing moisture from the air. This sounds like it is a condensate drain. You may be missing a hose or a pan or both, that collect the moisture removed from the air. This is the only reason I know of for any A/C unit to be discharging air unless it is a water cooled unit.
Sep 09, 2017 | Amana Haier AP125HD Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
How do I remove the back of the amana AP125HD portable air conditioner?
What are you trying to do? what kind of problem are you having?
Jun 30, 2011 | Amana Portable Air Conditioner
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
Heating & Cooling Logo
1,608 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
