Question about RCA P52926 52" Rear Projection Television
Won't come on. ptk195m1b, flyback is smoked. Need to find outlet for flybac and Horz out xister.
    Top Expert:
  • RCA Master
  • 14,553 Answers
Only generic ones now available----place with best price for both is SUBURBAN ELECTRONICS in Maryland (they have 800 number and also online catalog) Also they sell on EBAY--select advanced search and then search by seller--- sewsales55 is them.
SD TECH
Posted on Oct 14, 2010
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
TV WON'T TURN ON RCA F36650
Probably the horizontal out(HOT) is shorted. The flyback transformer is probably gone out also. For a 32650 the horz. is a 2sc5148 or a nte 2324. I don't know if the 36 is the same horz.or not . Hope this is helpful.
Nov 07, 2009 | RCA F36650 36" TV
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
I need to find a service manual for an RCA F32650 so I can replace a blown flyback transformer, preferabley free if possible
I have repaired many of these; if a high pitched buzz when you plug the set in---flyback and horz. output transistor are bad--transistor has a generic number on it--Flyback is location number LL05, part number should be 257805---you will find RCA no longer has this part--most now are replaced with an asti #2078----CHECK the RCA number on Ebay---company I get them from is Suburban Electronics---Flyback and transistor are less then 30 dollars for both.
Aug 06, 2009 | Televison & Video
MODEL - P52960 RCA
You have a flyback and horz output bad,price for this repair should be around 150.00 to 175.00,you also may just have a loose connection on the main board,if so price would be much less,because the flyback would not need replacing just the output
Jan 20, 2008 | RCA P52960 52" Rear Projection Television
NO PICTURE
Adjust the two settings on the back of the flyback with a phillips screwdriver...
Dec 16, 2007 | RCA F32650 32" TV
Wont come on
Need to replace the flyback and horz output transistor
Oct 27, 2007 | RCA P52920BL 52" Rear Projection...
TV JUST SHUT OFF
Ok your going to need a VOM meter and a soldering iron (25 to 53 watt, not a soldering gun). By no sign of power Im guessing that there is no click or any kind of "electronic" noise from inside the set. Ok, safety first, unplug the set and once you open it stay away from the high voltage anode wire that goes to the CRT (picture tube). In side by the power supply locate a resistor that should be at location R607, it is colored white and has a value of 0.1 ohm. It is most likely open, if so then most likely Q601 and Q602 are shorted as well, you will have to replace them and it is very important to also replace the following (shorted or not) R644 6.8ohm I think 1/4 watt and VDR601 VDR602 and VDR603 One of them is color black and the other two are green. I think VDR601 is the black one but dont quoat me on that. Next go to the Flyback transformer largest transformer in there (roundish in shape) near it is the Horz out transister I think it is location Q591, check with your VOM to see if it is shorted, if so replace it. Once you have that done solder the pins on the flyback and the Horz drive transformer, again dont quoat me but I think it is location T503. If you have a ESR meter check the electrolytic capcapscitors. Hope this helps! Good luck! Don
Aug 14, 2007 | Sony KV-32S25 32" TV
RCA P52926 52" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
