How to restart a Main Multipoint BF - Heating & Cooling
Why will my bathroom scales, Model TH 321 not show weight, but only zeros?-
SOURCE:Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Jan 02, 2018 | Health & Beauty
My 2007 BF Falcon wagon occasionally misfires when starting causing it to go into 'safe mode' with dash instruments flashing. The car can be driven with reduced power, sufficient to get home.
Your car should be fitted with an obd2 connector. Go to your local dealer and ask him to download the error codes on the ecu it will give the reasons causing the vehicle to go into safe mode.
Dec 16, 2013 | Ford Fairmont Cars & Trucks
I have a 2006 BF ute when i start it up it only runs for about 3 seconds sometimes i have to restart it 3 to 4 times before it will keep running when it runs for the 3 seconds it is like an old car when...
have the fault codes read and get some idea of what sensor/ servo has failed before you waste any more cash IT sounds like a MAF/MAP sensor or ambient air temp sender
Sep 11, 2013 | Cars & Trucks
Spark plugs blacsooty
mixture too rich ,so its either a blocked air filter or a faulty carb ,but no doubt its injection so it could be a faulty injector ,which one ?? well this depends on year of vehicle as is it a monopoint or multipoint fuel injection system ,iff all black then it could be monopoint but if multipoint then only one cylinder will be black if multipoint and all black then it could be the autochoke stemperature sensor faulty
Sep 21, 2011 | Volkswagen Camper Cars & Trucks
I have a Brittony 11 multipoint water heater can I run a Mira mixer shower of it?
Im thast gessing here bt if it says multipoint that means more then 1 water supply so i will say yes it would be fine if u connect ur shower
Bt best solusion here is if u dont wane get a plumber is go to a plumbing hardwere store with a picture of the device and thast ask them. coz i cant say for certen now, went on the internet bt dident find invo on that water heater for u sory. bt in my profession multipoint means more then 1 point .
Jul 16, 2010 | Home
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Empire BF-30-1 Main Burner problem
flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Jul 11, 2008 | Empire Heating & Cooling
PHILIPS 50P8341 60 IN.
Check the other posts for convergence problems. This may be what you're experiencing. Have you tried bringing it in with multipoint convergence? It's under Menu -> Picture -> Manual Converge -> Multipoint Red and Multipoint Blue.
Dec 07, 2007 | Philips 60PP9202 60" Rear Projection...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
