Question about ASUS P4XP-X Motherboard
Why is my ethernet is not working - ASUS P4XP-X Motherboard
  • 557 Answers
ASUS P4VP-MX Driver Download - [ Vertaal deze pagina ] 27 Jul 2006 ... ASUS P4VP-MX driver download. To download P4VP-MX driver read the instructions below. ... Download ASUS Motherboard Driver. P4VP-MX preview ...
www.nodevice.com/driver/P4VP-MX/get34110.html - In cache - Vergelijkbaar
Posted on Oct 14, 2010
Ethernet light does not come on cant connect to internet
Try replacing the ethernet cable, if that doens't work then try to reinstall the driver, if that doens't work then that means the ethernet port could be defective.
Feb 28, 2011 | Computers & Internet
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
Specific Ethernet Cord Input?
Some cords are designed for desktops and laptops and some are also ethernet phone cords for dial up users and if the short one works congrats. hope this mke you understand better.
Jan 08, 2010 | Compaq Presario 700 470024-192 Notebook
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Oct 13, 2009 | Cisco 857 Router (CISCO857K9)
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
The ethernet port doesnt work or doent recognize
install the right driver for your ethernet.
check your hardware device manager if your network card is present..if there are unknown devices that might be your ethernet. install the right driver
Mar 20, 2009 | Compaq Computers & Internet
4100 Modem telling me to install ethernet adapter
You do not state if the ethernet had been working before. If this is the first time to use the port on the computer, it often needs to be turned on in the BIOS of the mother board.
Nov 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
About ethernet
If you computer has already a ethernet card installed on it, just need to get a ethernet cable and connect it to your modem and the other to the computer and make sure the USB is disconnected already, then power off your modem and restart the computer then power the modem back on and check if internet is already working, if its not working you may need to contact your ISP and tell them to enable the ethernet connection of your modem....
Sep 14, 2008 | SMC Abocom ExpressCard to Ethernet Network...
Westell 6100 ethernet
the prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Jul 26, 2008 | Westell Wirespeed LiteLine 6100...
ASUS P4XP-X Motherboard Logo
220 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
