Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I tried the hex wrench, and resetting it, and all the advice I've heard so far, with no luck! Help!
  • Ace Hardware Master
  • 43,501 Answers
Hi, The motor has gone bad...
Here is a tip that I wrote that will help you to figure out what is going on
with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Oct 22, 2010
Need hex wrench for intex control unit
if bought new the multi tool is included if used any hardware/or store selling tools carries the hex key
Jun 11, 2017 | Cars & Trucks
How do you remove the front passenger door panel on 2000 Yukon when you cannot open the door
I've heard it can be done with some difficulty. It may help to unbolt the passenger seat and move it as far over as possible to get to door panel screws and fasteners. Take all the screws out and pop the bottom retainers out. Good luck. Let us know if it was possible.
Nov 26, 2011 | 2000 GMC Yukon XL
I can't figure out how to change the blade.From some of the other comments I've read , a lot of other people have had that same problem. So, how do I do it?
UNPLUG tool, remove the throat plate (piece that goes around blade) there are 2 wrenches that were supplied with the tool when new. One fits on the flats on the spindle and the other fits on the hex nut, what I generally do is brace the spindle wrench on the table of the tool and then with the hex wrench pull to loosen. You might have to TAP it with a small hammer to loosen, WEAR gloves when doing this to save scrapes on the hands. Let me know if you need more assistance.
May 24, 2011 | Bosch 4000 Factory Reconditioned 10"...
I cannot get at the positive pole screw. It's semi hidden
You have to take the hold down mechanism loose, then disconnect the negative screw. Pull the battery out of the battery box far enough to get to the screw. You may have to use a wrench to remove the screw. Usually they have a hex head on the screw.
Good luck
steve
Oct 17, 2010 | 2007 Harley Davidson XL 883 Sportster
Changing rear rotors
ve wheel and then remove rotor if it has a locknut then remove that first and then the rotor should come free be sure and remove the brake caliper first the two bolts are located on top and botom of the caliper on the inside it requires a either a hex wrench or a starbit type of wrench...
Dec 17, 2009 | 1998 Ford Explorer
Disposal hums but doesn't rotate. I would like to know where the reset button is so I can see if that is the problem. I've tried turning the inside mechanism but it won't rotate...
There are several things you can check. First make sure the unit is off and check for debris stuck inside the unit. On the bottom of your Disposal is a slot for an allen wrench also most have a reset button here also. First take the allen wrench and turn the unit around several time manually before you do anything else. Now run some water down the unit and see if it will turn on. If it doe not try the allen wrench one more time and do the same as above. Now try the reset button. If this works great because the next step requires you to take the unit off. Let me know if this works before we go to the next step. Hope this helps.
JimmyC
Oct 08, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Deore front derailer cable stay hex nut access
Try unhooking the chain from the ring and pulling the derailleur out far eough to get at the bolt. Make sure your limit screws are adjusted for the travel yuou want and take up the slack. You can use the cable adjuster on the shifter to tighten it or loosen it as necessary. Make sure the adjuster has enough to go in the direction you need. I don't know which model Diore you are talking about so this is the best advice I can give you.
Jul 04, 2009 | Shimano Deore Xt Thumb Shifters 7...
Replace fan belt
Here is a diagram http://www.2carpros.com/car_repair_information/tec_info/2002/ford/mustang/2002_ford_mustang_drive_belt_routing_diagram.htm
its pretty simple use a wrench/hex which ever applies to the nut that on the tensioner some vehicle have a regular bolt type and some have a hex. Just follow illustration and push on tensioner using proper tool and release tension and belt and the belt will come and replace using the routing diagram I provided. Good Luck and Thanks for using FIX YA contact if you need more help.
Dec 31, 2008 | 2002 Ford Mustang
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
95 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
