Question about Goldstar MV-1501 Microwave Oven
Goldstar MV-1501 1000 Watts... Problem:
Everything still works except turntable & heating.
  • Goldstar Master
  • 5,568 Answers
There is no 'heating element' in a microwave oven unless it is a combination oven equipped with convection heating.
This model does not seem to include that.
If it was only a failure to heat, it could be a failed magnetron, but the fact that the turntable does not rotate, implies that a door switch has failed instead.
These may not be easily accessible so if the unit is not under warranty anhy more, you may be better off adding to the problem of waste disposal and replacing it with a new one.
One post in particular was disturbing:
http://www.epinions.com/content_184983064196
Posted on Jun 02, 2008
    Genius:
  • 1,224 Answers
If micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
Jun 27, 2012 | Goldstar MV-1526 Microwave Oven
MICROWAVE NOT HEATING AND TURNTABLE NOT WORKING BUT EVERYTHING ELSE DOES. WHAT IS THE CAUSE OF THIS?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
89r
Nov 30, 2009 | Goldstar MV-1155 Microwave Oven
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar MV 1501BQ microwave
It's probably a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar microwave mv-1526 1000 watts
the bullet fuse to the klystron circuit may have blown
it is a thermal bullet fuse ,
google that to see what it looks like.
if you have a ohm meter it will give low ,closed resistance.
Apr 25, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
No heat
The most likely causes are defective a door switch (or switch mount), a bad connection in the high voltage section, or on the controller. I would direct you to my safety text file and door switch text file for critical safety info anf info on testing & replacing door switches. You can find it via searching on Yahoo.com (not Google) for: microwave safety.txt After you check that out, please repost so we can hel you further.
Nov 27, 2006 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
191 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
SHARCNET-USA
SHARCNET-USA
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
