Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 Stopping at prewash
Hi there I have a Hotpoint wf540 washing machine, and it just stops at the prewash part. I have left it on for hours and it does not do pass that point, I have switched the machine off from mains for 30 min and tried again, no luck.
A little water enters the machine at the prewash part but it just seems to stop there, prewash light will just flash away.
Would like some help please
  • 66 Answers
Sounds like water valve problem
Posted on Jun 15, 2008
My hotpoint wf540 on off switch flases and the
sounds like your water pump has failed??
Try cleaning the filter first, normally accessed at the bottom R/H side of unit at the front.
If not, replace water pump (approx £35 for part) good luck!
Jan 04, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi My Hotpoint WF540 1400 spin is stopping mid cycle and not draining, rinsing and spinning unless I stop the cycle and choose just rinse and spin. Any suggestions? sarah
Probably needs the filter cleaning.
Remove lower rear panel.
Remove large black hose onto drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Nov 16, 2009 | Washing Machines
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Hotpoint wma34 stops and prewash light flashes
I would check the water pump for a blockage a button or other debris may be lodged in there preventing it for operating properly eric
Jan 15, 2018 | Hotpoint Aquarius WMA42 Front Load Washer
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dont understand what the programs do
my hotpoint aquarius wf540 lights keep flashing
Mar 01, 2008 | Hotpoint WMA31 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
546 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
