Question about Maytag Washing Machines
My maytag washing machine leaked a small amount of oil when we transported it from a Sears store. The amount of oil was less than an ounce. We did lay the machine on its back while transporting it less than 2 miles. The Sears store assured us that laying it on its back would pose no problem, what-so-ever. Should the machine have leaked oil?
  • 868 Answers
That much oil is nothing to worry about at all
Posted on Jun 02, 2008
Where to get replacement hoses to pump.
I would go to your local hardware store to see if you can replace it for less. If you can bring it in with you that would be best. Otherwise Google sears parts and find the part online to order.
Oct 19, 2015 | Maytag Washing Machines
Maytag MHWE400WW01 fills with a small amount of water when not in use
Selenoid valve leaking. Could be a rubber washer or complete valve or very low water pressure.
Dec 08, 2013 | Washing Machines
Checking oil in ac compressor 1994 chevy g20
the only oil amount you can check is remove a/c compressor
place it upside down(or drain plug) oil will drain in mesure cup if you find less than 1 ounce then pour 2 ounces in compressor
there is around 8 ounces in system
2 ounces compressor
1ounce evaporator
1 ounce condenser
1 ounce dryer
3 ounces for tube and the rest
Oct 18, 2013 | Chevrolet G20 Cars & Trucks
Dont know what the oil gas mixture is suppose to consist of
Your manual (from Sears) states that your mix ratio is 40:1. You will need 3.2 ounces of Poulan "Pro" synthetic 2 stroke oil mixed in 1 U.S gallon of gas or you can mix 1.6 ounces of the oil in a half-gallon of gas. They suggest using the Poulan "Pro" brand synthetic oil. I do also. Synthetic oil significantly reduces wear, allows the machine to run cooler, and burns cleaner with less by-products and emissions. You can view a PDF file of your manual here:
May 01, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Seal a round shaft of transmission leaking what oil does the transmission require
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive washer.
See the following Whirl[pool parts list for their commercial washers although the consumer models use the same transmission and parts.
The part you need is probably the 3349985 Seal, Gearcase
Cover, a relatively cheap part.
I've found that basic 80-90 weight non-detergent gear oil ( available at auto parts stores) seems to work well. It's certainly less expensive than the gearcase oil from Sears.
Feb 12, 2010 | Kenmore Washing Machines
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washer 5401A
this is a leak in your triple lip seal that has seeped water into your bearing. this requires special wrench and experience to change
Feb 13, 2008 | Maytag SAV5401A Top Load Washer
Maytag MAV6000Aww washer-loud noise when spinning
Chances are it is not the tub. It is probably the transmission. It has been my experience that the transmission bearing starts to make noise. Look under the unit to see if you can spot any transmission oil. If there is oil, it's time to start shopping for a new unit.
Sep 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Oil leak
A small amount is not serious. There is no good way of adding oil to the transmission unless you want to take the top off the transmission.
Jan 21, 2007 | Whirlpool LTG5243D Top Load Stacked Washer...
Open Questions:
Washing Machines Logo
159 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
