Question about Kenmore Elite 45986 Front Load Washer
Error f-dl - Kenmore Elite 45986 Front Load Washer
  • 2,272 Answers
The door lock and door itself is to be checked.Is the door closing properly or is it remaining open.Check and confirm it.If the door open/close properly then its the door lock latch problem.It has to be checked and replaced.The FdL error code indicates a problem with the door lock assembly on the washer.The control board detects that the washer door is not locking properly. Replacing the door lock assembly will normally fix this problem. It can also be caused by a wire harness connection failure or sometimes by a failed control board.But in most of the cases its faulty door lock.To get the required parts you can get it from.----------- www.repairclinic.com -------- -------------- Keep updated for any further queries.Thanks.
Posted on Oct 14, 2010
Receive a DL error when trying to start my front load washer (the door will not lock)
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting the code dl and F on my whirlpool duet washer model # GHW9150WO
Thank you
Jul 17, 2010 | Whirlpool Washing Machines
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont turn on. code is F dL. any thoughts?
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Dl code
Thank you !!
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error "F DL" cycle won't start
F DL is a door lock failure. The door is not locking so the machine will not start.
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Robert Rankin
