Question about Canon Selphy CP510 Thermal Photo Printer
My CP510 printer is only printing half the image
    New Friend:
My canon cp510 photo printer printed only half of the photo (only the left part if you look to printer whith papercartridge towards you)
I repaired:
Put cp510 upside down
Open box by 4 little screws philips and three bigger. turn upside again and wathc out for little screws
Get off the plastic box, topside, and i found:
(when you have the printer like "normal"i mean with entrance for paper cartridge towards yourselves )
I find from left to right a metal axle of about 5 mm diameter. on right end i found a white plastic thing whcih puts down the printing head/ink foil casette. It was broken arond the axle, it was torn due to pressing so often., I suppose.
Dutch official Canon repair shop said i could not get a spare one as they could not order spare parts, they expected.
Anyway. i reparied it myself with super glue:
To get iron axle free, in order to get broken plastic "pusher" off, I first unscrewed to bigger screws in the metal plate on left side and also the very litltle screw on front side (on/off switch. This all to give space to axle when i want to lift it up on right side.
I got off also bottom plastic house, then you keep iron house , on right corner on front side the metal side is screwed to a metal bar with a very little phillips screw (1,8 mm screwdriver). It is very fixed, so you have to push very well on screwdriver, and i got screw free. then i pulled teh right wall on topside a bit so that i could just get out teh iron axle from that right side wall an lifted it up and pulled off plastic broken/teared part.
With thin paper i cleaned the tear (from any fat/oil form machine) and put some superglue on it, put it back on axle and i had allready some little clamps ready to pressure on plastic part.
Please note the axle is not round at the end, but there is a space to be able to push the plastic part down. So look well that you put plastic part on axle back in some position.
Of course you can make photo's during repair in order not to forget how it was together..
The immediately. put presses or clamps on teh plastic for the necessary pressure (I used little, but strong clothes pins ).
after a day of drying. i put togetehr machine an d it worked again. allraeady 10 photos upto now. hope it will work for several years agian !.
note: afterwards, i read, i schould have used special super glue for plastics.
Have success.
Frank
Posted on Aug 05, 2013
    Problem Solver:
  • 19 Answers
You can try reinstalling the latest driver/software. this will probably resolve your problem. Here is the link for the driver/software:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Could use a little more information. What transpired just before this started happening, what kind of system do you have? What operating system are you running?
Posted on Oct 14, 2010
  • midnightt329 Jan 29, 2011
    I'm getting the same problem and I'm printing directly from a camera please help
  • Sarah Nov 05, 2012
    I am having this problem with a SELPHY cp800 printing from USB, CF and my mac, no solutions online anywhere!
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Aug 12, 2014 | Sony Picture Station DPP-FP90 4x6 Photo...
Prints half page
It is because of a split little white pawl on a rod above the cartridge on the right hand side of the printer.
The pawl pushes down the print head and when the pawl splits, it doesn't push down far enough to print on RHS.
I've tried using a tie strap to repair it but it interfers with adjacent parts.
Jun 25, 2014 | Canon Selphy CP510 Thermal Photo Printer
Canon selphy cp510 printing spuneti
Typically the paper pickup rollers need to be cleaned or replaced.
Pickup mechanism may be damaged as well.
If you attempt to clean use 100% isopropyl alcohol with caution.
Nov 22, 2013 | Canon Selphy CP510 Thermal Photo Printer
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Mar 16, 2011 | HP LaserJet 1020 Printer
Canon Selphy C510 connected and has driver but does not print from computer file. Prints fine direct from camera......
copy all the files to the computer then unplug your camera. It will print your files from the computer. Dont forget to check your printing settings.
May 02, 2010 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Printing marks
I had issues like this, and changed to thinner paper. That solved my problem
Jan 01, 2008 | Canon Selphy CP510 Thermal Photo Printer
Canon selphy cp510
pull open the blue flap at the front, cartridge goes in there.
Jun 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
1,104 people viewed this question
old marine
old marine
