Question about RCA HDLP50W151 50" Rear Projection HDTV
Hd50lpw175x7 Thanks so much with all your help. Joyce
  • wilbonis Aug 04, 2008
    no picture or sound. no response to remote or manual on-off switch. Blue display blinks. lamp is good.
  • RCA Master
  • 8,617 Answers
Youre welcome
Posted on Jun 02, 2008
Water fills but won't stop filling-overflows and won't spin out
This is joyce
You might want to check into the Valve that lets the water flow into the machine or it may be the switch that controls the water flow to the machine, it is either one of the 2. go to maytag.com and dowload your document to your machine type and see if you can get help.
let me know how it goes
thanks
joyce
Feb 19, 2009 | Maytag Performa PAV3200
Cant get door open
this is joyce.
I am not sure what is going on with this unit but try this first unplug unit from wall and try to reset it and see if this will let you open the door, if not you will need to call whirlpool to get help. go online to whirlpool.com and get their # or their website is whirlpool.com
thanks
joyce
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not hold water
This is joyce
Go to Maytag.com put in your model# and download a manual to your machine and find what you need. they have wiring diagram and all. if you really want to fix yourself, if not let me know and I will help you find someone in your area to help.
thanks,
joyce
Feb 06, 2009 | Maytag Performa PAV2200
Lost retainers, possibly in washer
this is joyce
It is not possible that the retainer is under the aggitator, it usually would be in the bottom of the machine.
I hope you find it.
thanks
joyce
Feb 06, 2009 | Kenmore 24032\24036 Top Load Washer
Padlock sign has turned red and washing machine doesn't work
This is Joyce
try to unplug the washer for 1 min and replug back hopfully that will do the trick. if not go online to brandt.com and put in your model# and download you model# and download your manual to get information on your model to unlock.
hope this helps
thanks
joyce
Feb 04, 2009 | Brandt WFH1276F Front Load Washer
Hoover VisionHD won't drain
This is joyce
I think you better check to see first of all if it is your pump,, that is the first thing to go.
thanks
joyce
Feb 03, 2009 | Hoover AAA140 Front Load Washer
Frigidaire front load washing machine, the screen display DO
This is Joyce
If you are trying to fix this yourself you can go online and download a doc of your washer from frididaire.com put in model and then it willl give you doc you can download and fix yourself or you can call techn. if you need help finding one in your area I will be glad to help.
thanks
Joyce
Dec 22, 2008 | Frigidaire GLTF1670A Front Load Washer
My washing cycles just fine and will complete each cycle until the buzzer goes off but never drains the water
This is Joyce
This sounds like you have a bad pump, if you are a handy person you can do this yourself, but if not you may need to get help from techn. if you need help finding one in your area let me know.
thanks,
joyce
Dec 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hd50lpw175x7
The power supply is what provides all the standbye voltages that get routed to the various other boards. The capacitors have to be unsolderd and the replacements solderd in.
May 29, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
27 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
