Question about Cuisinart CBM18 Electric Grinder
My cuisinart cbm-18 does not grind at below a 10 setting?
  • 2 more comments
  • alandavis1 Oct 14, 2010
    the solution offered is basic. The machine has been properly cleaned each time used. Removal of lift out burr etc.
    It is only 4 months old - yet cuisinart says it is out of warranty as I am Mexico
    As I said before I CLEAN the machine WELL every time I used it. And I mean well. It does not grind below #10. The burr grinders are not in the least worn.
    Thanks, but you did not read my comments. That the unit is new (3 months) grinders look NEW and not worn in the least.
    Unit is only 3 -4 months old. Grinders appears to look like new. It did grind very well, then one day it stopped grinding on anything less than #10 - drip. I need it for espresso.
    The machine was cleaned after every use - well cleaned
    Guru:
  • 773 Answers
Part of the resistor pack, which regulates speed has burnt out or the switch is malfunctioning. It needs repair or replacement.
Posted on Oct 14, 2010
You will need to clean your machine out to get it working right again. Click on the link below to view the Cuisinart CBM18 cleaning/maintenace instructions:
http://www.cuisinart.com/share/pdf/manuals/cbm-18.pdf
  • 13,433 Answers
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
  • 22,156 Answers
You would need to strip it as i think it might needs gear grinders they are worn out which is what happens when something is used a lot ,The local agent might be able to supply or look on internet for the manufacturers web site ,sometimes you can get spares other times its a bin job and buy new
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker's on/off light is blinking and cant get it to start
Hello. Please check to make sure the grinder is assembled properly and the lid is completely closed and snaps shut.If all this isn't right it will make a beeping sound.If that doesn't help unplug it for a few minutes and start over with the time setting etc. If you dont have a manual you can download one at www.cuisinart.com.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Oct 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker
hi
check your settings, or maybe you have defective thermostat...
Thanks
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Need product Manual
Go to this link http://www.cuisinart.com/manuals/index.php?cat_id=3 There are a couple of different 10 cup G&B machines Hope you find what you need :)
Mar 30, 2007 | Cuisinart Grind and Brew, 10 cup, white
Cuisinart CBM18 Electric Grinder Logo
429 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
