Question about Delta 15 331 15" 115/230V Variable Speed Standard Drill Press
I have a Guardian Power 3 speed heavyduty drill press, model BDM 38-3S, capacity 3/8, spindle JT 2 1/2, motor 1/3 hp, serial 182263. a piece of plastic that fits on the spindle of the drill, which in turn holds the depth finder guage is broken. Where do I find this part?
4 Suggested Answers
  • 760 Answers
SOURCE: I have a Guardian Power floor model drill press.
Can you move the spindle up and down with the handle? If you can't make sure the spindle lock is not on. Is the spindle clean and rust free , well lubed? Here is a link to a manual for your drill press: http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=15-331 You can order parts here. Usually the return spring can be adjusted with a nut on the left side of press. Possilby the return spring could be broken.
Posted on Jul 12, 2010
puertobori
  • 7733 Answers
SOURCE: I have a Guardian bench mount drill press Model #
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
  • 11 Answers
SOURCE: I have an old Guardian
sounds like either the pulley is not tight to the spindle or the spindle is broken in half either in a bearing race or between the two spindle bearings
Posted on Mar 18, 2011
Guardian Power Drill Press BDM-58-12S Manual
Try Googling (Guardian)(BDM-58-12S)(manual) without parens.
Apr 05, 2018 | Drills
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Mar 22, 2011 | Milwaukee Tool 4253 1 Drill 1/2 Mag Motor...
I have an old Guardian Power 3/4 HP 12 speed drill press. When the drill is on, I can hold the chuck with my hand. The Pully spins the but spindle is slipping...got any suggestions
Feb 26, 2011 | Drills
I have a Guardian Power floor model drill press. The spindle will not retract. I would appreciate knowing how to fix this and where I can get parts. Thank you. Bill Powell
Jul 12, 2010 | Delta 15 331 15" 115/230V Variable Speed...
I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
Apr 17, 2010 | Drills
Would like to replace the 3/4 Chuck on Jet Drill Press
Grizzly sells a nice variety of quality chucks at good prices. Look at the numbers on the chuck you have to determine what to buy. You should remove and re-use the taper from your present chuck. You probably have a Morse #2 taper up into the spindle like the picture shown below. I assume you know 92bb256.jpghow to get that out of the spindle. What is not shown in this picture is the taper that is inserted into the chuck. This is probably a Jacobs taper. To separate that you need to support the chuck in a vise with the long taper pointing down. Put something below it to catch it without damage when it falls out. Open the chuck as far as it will go. Get a bolt (about 3/8) that you can hit with a hammer inside the chuck straight down to knock the taper out of the back of the chuck.
Apr 12, 2010 | Jet 354170/JDP - 20MF 1 Drilling Capacit...
How do I remove the spindle gear to replace the
find a schematic for your tool and it will show you how things go together. you may need a press to press it out or a gear puller. if the schematic shows spendal and gear apart you should be able to remove the gear. if it shows all one piece, then you replace the whole thing.
Apr 10, 2010 | Milwaukee 1101 1 Drill 1/2 500 D Hdl
Drill Presses problem
If adjustments are necessary, follow the this procedure: Spindle side-play can be minimized by adjusting the locknut located on the left side of the motor unit 1-1/2 inches behind the spindle and towards the bottom of the motor unit. While moving the feed handle up and down, tighten the lock nut until the play is minimized, but not so tight so as to restrict free movement of the spindle. The spindle should return by itself to the full up position. The drive belt tension may be adjusted by removing the top cover and then loosening the two nuts on either side of the motor pulley. Adjust the motor position and tighten the nuts so that moderate finger pressure against the belt causes it to deflect 3/16" to 1/4" (see Figure 6). Excessive belt tension may result in damage to the bearings. Note: Belt tension can also affect the generation of "noise" in the drill press. Although it does not affect drilling accuracy, it may be desirable to adjust the tension for minimum noise. The spindle has been generously oiled at the factory. You may have to periodically wipe off oil that makes its way down the spindle.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Delta 15 331 15" 115/230V Variable Speed Standard Drill Press Logo
655 people viewed this question
Top Delta Drills Experts
DocZachary
DocZachary
Bill Boyd
Are you a Delta Drill Expert? Answer questions, earn points and help others
