Question about Bosch Exxcel WVT 2850 Front Load Washer / Dryer
How do we access the filter on Bosch washer dryer WVTi2840gb _ does the cover slide off or is it prised off
3 Suggested Answers
BMT60
  • 126 Answers
SOURCE: Bosch Axxis WFL 2060 Washer, not spinning.
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Posted on Apr 25, 2010
Macmarkus
  • 2605 Answers
SOURCE: I just got a Bosch
Welcome to FixYa.
i'll start with the most obvious, but still quite common oversight, have you remove the shipping bolts from the rear of the washer ?
i.e.
The next thing to pay close attention to is detergent usage. Regardless of what one may have been told, "He" detergent has to be used, and even then not too much.
Look for this symbol when buying/using detergents...
These are the most common things that can (and DO ) contribute to the machine acting in the manner you've described.
If neither of these things apply to your situation, please let me know and I'll be glad to assist you further.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Oct 07, 2010
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Can't get the clips off the bottom of dryer even with putty knife
Why would you want too ? Did you break em? Just prise them off there if that is the case. They slide and lock into position and are not needed to be removed at any time unless they were broken because you forgot to lift the front before removing it. Cannot make that model number work.
Their are basically 2 styles of this washer Filter on top or filter inside. Which is yours and what is wrong with the dryer ?
Dec 29, 2012 | Kenmore 700 6972 Dryer
Can't open filter on Bosch exxcel washer dryer
i reckon you probly had some stuff in yer pockets so don't blame the kids, anyway the filter door is probly jammed up over time with lint and stuff (should be cleaned regularly) so git a screwdriver and prise the door open and clean out all the stuff in there..All good to go again.
Nov 05, 2017 | Bosch Washing Machines
My Bosch WVF 2402 will not drain
Tyere should be a filter located at the bottom right front of washer, behind a drop down cover.
Unscrew anti-clockwise to remove and clean.
Dec 30, 2009 | Bosch Classixx WVF 2402 Front Load...
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
My bosch exxcel has water sitting in bottom and doesn't appear to be draining down.
Check to see if there is a removable lower plastic cover at front of washer, if there is, then remove this, and you should find the pump filter located here, unscrew anticlockwise to remove and clean.
If no sign of filter, then remove rear panel of washer, and access the pump from here to check for blockage.
Thanks.
Nov 09, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Can you supply me with instructions for a Bosch washer/dryer
Bosch Product web site.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Click on WVTI2840GB/04 for info.
The model number has the letter "I" not "1"
Mar 03, 2009 | Bosch Washing Machines
Timer switch has broken on bosch wvf 2401 how to replace?
First remove screws X2 from back of the machine that hold the top cover on. Once removed the whole top slides backwards and can then be lifted off. This gives you access to the plastic clips that hold the timer face panel on. The main control dial must first be pulled off through the front cover, then remove the front cover by unclipping it (a pain and a fiddle!) The dial on the timer can then be pulled off revealing the two mounting screws that hold the timer in!!
Feb 02, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
Aug 10, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
