Question about Whirlpool Duet GHW9150P Front Load Washer
Washer no start no error codes
I am certain if your washer will not start and appears for no reason it shouldn't. it is your door latch. Look inside the door on the machine and find the spring loaded switch. It is likely black and has worn away to nothing. place a toothpick inside to push it in or similar screw size. when you close the door the switch will be out enough to activate.
Good luck
    President:
  • 331 Answers
What?
Posted on Jun 13, 2008
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
I cant get my washer open theres a dl code flashing
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2010 | Kenmore 45981 Washer
MY washer door won't open and there is no display.I tried to press cancel button, start and push nothing works. Please help. There are still clothes in it.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Oct 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3T. Door won't open.
Tip Courtesy JSRock
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore Elite 45986 Front Load Washer
My GE front load washer (wcvh6800) starts but won't complete even the first part of the cycle - shuts itself off with the door locked. Any ideas appreciated.
The timer is failed.
Jul 11, 2009 | GE WSXH208A Front Load Washer
Panel will not unlock
The lock/latch has likely failed.
Jul 10, 2009 | GE WSXH208A Front Load Washer
Lcd showing dle error..machine stops
Door Lock Error.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" "DLE" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 07, 2009 | Washing Machines
My new whirlpool duet front load washer shuts off immediatly as soon as it starts and the door stays in locked mode. you have to jiggle the door and keep pushing the start botton and eventually it will try...
Mar 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Resetting washer after the problem is fixed
Did you unplug the washer at any point while you were repairing it? Normally, to reset some minor glitches with the washer all that is required is to unplug the washer for at least 30 minutes. This will reset the CCU. If you had the power secured, the problem SHOULD have gone away with the installation of the new door latch. Unless...you purchased a defective door latch, or have a faulty wiring harness. What was the error code you originally experienced? The reason I ask, is because if this is a Kenmore Elite Front Loader as the one pictured above, there is no "lf" error code. "Fdl" and "Fdu" error codes are usually the indication of a defective door latch. Could you please post back and clarify this information for me?
Sep 28, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE WASHER error (DL) then (F)
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 07, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
