Question about Vtech mi6896 Trio Cordless Phone
My Vtech 6896 quit ringing on all phones. The phones will light up when the call comes in, but won't ring. I have reset the program on the base phone.
  • 2 more comments
  • swjobs Oct 14, 2010
    That did not fix the problem.
    The advice I received was insufficient, I need additional assistance please
    I tried this but it did not work. Is there anything else I can do?
    I have tried the other suggestions but this did not work. I need additional assistance please
    Genius:
  • 1,478 Answers
Have you try to reset it? If no, Just try to reset it to factory settings.
Remove the AC Adapter from the AC power (either at the base or at the wall outlet) and immediately connect it again. Remove battery from the handset and immediately replace it. Place the handset back into the charger for about 5 seconds. That should reset the phone and put the phone on default and should fix the problem..
Take care.
Posted on Oct 14, 2010
    Genius:
  • 1,456 Answers
Hello
First of all please check your phone ti ensure that the ringer is not turned off.
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Check the side of your phone for a ringer switch,flip it to the other side and check to see if the phone rings.
If the phone still doesnt ring then the ringer of your phone is faulty and it needs to be replaced.
    President:
  • 2,185 Answers
Try taking the battery of each unit off and then wait for like 5 minutes then return back and power the phones on again.
How do I set ring tone on base unit to match handset
You didn't state the brand and model of your phone, but my vTech and Uniden phones only have ONE RING TONE on the base, and it can only be turned ON or OFF (and the volume is variable on the vTech).
May 13, 2015 | Lands Phones
No ring
This is more likely a faulty socket, make sure it has a master socket with a capacitor in it
Jul 03, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
My vtech digital 6.0 cordless phone says not registered but when someone calles the base of the phone still rings and people are able to leave messages but the actual phone isnt ringing, how can i fix it?
The base and the handset are not communicating. To have them do so, you need to "register" the handset with the base. Since you neglected to specify the model of your VTech DECT 6.0 phone I can't tell you how to do that. I can suggest you enter the model number into the search box here to download a copy of the manual. The manual will give you instructions on how to register the handset.
Jun 22, 2012 | Vtech DECT 6.0 Digital Cordless Phone
My phone is model #CS6328-3. Base is saying
unplug a/c cord from wall for the base... remove all batteries from handsets ley sit for 10- 15 mins then plug base back in put battery in one handset at a time return handset to base let charge, then reset base station and handset to same settings...
Nov 30, 2017 | Lands Phones
My phone won't stop ringing when someone calls. it has a steady ring and it rings after you hang up. the caller id won't pickup who is calling. how do i fix it?
Try to reset the telephone base by unplugging the unit's electrical power. Wait for 15 seconds and plug it back in again. Allow up to one minute for the handset and the telephone base to synchronize.
Apr 01, 2011 | Vtech CS5121 Cordless Phone
Vtech phone does not ring on incoming calls
hi I have new vtech cs6859 just I buoth yestarday the doase not ringing
Jul 23, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
My vtech 5.8 two handsets won't ring
put each one into the base charger and watch the battery light flicker.
that should sort it out. you can also try unplugging the base for about 10 minutes first to reset it.
please take a moment to rate this solution thanks
robert
Sep 04, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
Jun 06, 2009 | Vtech CS5121-2 Cordless Phone
Changing rings before machine cuts in
Since you declined to specify the model of your VTech DECT 6.0 system, I can only direct you to enter it into the search box here to download a copy of the manual.
Jan 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech mi6896 Trio Cordless Phone Logo
187 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
