Question about Alpine PDX-2.150 150W x 2 Car Amplifier Car Audio Amplifier
Hi.i've got Alpine PDX-2.150 Car Amplifier and one day it blow the fuse's.i checked and it was blown MOSFET's (all 4) replaced them ,now amplifier's blue lights turn on but MOSFET's heat rising very quickly,overheating, and you can hear little ticking noise from the power transformator.any ideas how to fix it?thank you.
  • 2 more comments
  • mindeeez Oct 14, 2010
    what is the IC? thank's
    didn't expected that,but true IS true.thanks for your answer.
  • mindeeez Oct 15, 2010
    hi.i just replaced IC and all MOSFET's ,checked END transistors and other transistors,diodes,nearly everything and it looks ok.no shorts anywhere.no damage on board tracks.but problem is still the same.mosfets overheating.how can i start trouleshoot? what to look for or where to look for and how? please heeeeelp:) thank you for your previous answer.
    i think that would help,but it's too difficult for me...any simplier ideas what i can check using tester? or where to get an info or where i can try to learn how to fix car amplifiers.find a burnt or shorted part is very simple,but testing amps with audio generator or something similar it's to complicated...but thank you once again for your patience.
  • 11,800 Answers
The mosfets heat up very quickly because they are uncommanded so they are fully open, putting a huge stress on the transformer. The little ticking is the autoprotection of the source trying to kick in.
The entire amplifier has been fried - you will have to replace all the preamplifying IC's and the driver transistors (the ones that command the mosfets). After that you will have to check the board itself for heat damage - burns, bad solderings, damaged resistors and capacitors.
Posted on Oct 14, 2010
  • 1 more comment
  • Azrael SRL Oct 14, 2010
    IC = Integrated Circuit
  • Azrael SRL Oct 15, 2010
    Inn that case the signal doesn't reaches the finals. Use an audio generator - set it at 1kHz - at the input of the amplifier (make sure the output voltage of the generator is set to no more than 2 volts) and then using an good voltmeter - one that can measure peak values in the audio frequencies range - check where the signal stops, there you will find the failed part.
    Of course test that using a standard load - a good pair or 4 ohms speakers that are capable of handling the power will do in a pinch.
    While you are there make sure the speakers in your car are in good order.
    Without at least a good voltmeter you can't do very much- check the voltages with and without a signal present , if they don't change then the part in question doesn't receive the signal - start from the speakers output.
Alpine amp not working.
possably, did you get it professionally fitted? they have lifetime warranty on install,
Apr 22, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I had 3 subs hooked up to my pdx 1 1000 and it stopped playing one day and hasnt played since
1. check your B+ wire and make sure the fuse is good, and your ground wire and are you certain that the remote turn on is good?
2. If you have 3 subs runninng on the amp i hope those subs are 8ohms and you wired them in parelell to give an impedance of 2ohms. Let me know. Mark @ Sounds Good to Me.. tempe, az
Mar 18, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car amplifier wont turn on
Your best bet is to call Alpine directly at: 1-800-832-4101
Jul 15, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I just purchased and had installed an alpine pdx-1.1000 amp. powering 2 12" jbl's. while the owner was demonstrating this to me, we had it going loud, and it blew its 4 fuses. once he replaced the fuses,...
Technically, the manual says the amp should have 20A fuses, so by putting 25A fuses in, you've allowed more current to get to the amp before the fuses blow than recommended. I'd be more concerned about why the amp is blowing fuses.
If the subs are single 4 ohm voice coils and wired in parallel, you're fine. If they're dual 4 ohm voice coils, and everything (subs and voice coils) are in parallel, you're putting a 1 ohm load on the amp, which it's not rated for.
Mar 17, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Blown fuses
This is a sign the you have poor voltage regulation. Which may mean that you are taxing the electrical system of your vehicle. I would suggest you adding a secondary electrical supply for you audio system. This can be done by adding an extra alternator and voltage regulator and battery supply. This will allow you to drive your audio system without having it (power supply) split between the vehicle and the audio system. The fact is your system is drawing to much current for the unit and your vehicle. You are blowing the 20-amp fuses which means the the amp is creating a currnet draw which is past the rated value of the fuses, which if done too many times could damage the power amp components in the unit. I would also check the ohmage reating on the speakers connect to the unit since you may have the wrong impedance which may also cause excessive current draw and actuate some sort of overcurrent protection.
Aug 31, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-2.150 150W x 2 Car Amplifier Car Audio Amplifier Logo
131 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
