Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
I can get into the GUI of the router so I have the correct password. However after I have set up the WEP encryption it then asks me the password again and will not accept what I put in.
  • 13,433 Answers
Hello, and thanks for using FixYa.
you can't put just anything into the password field, depending on if the password is set to HEX or ACII you have a certain amount of letters or numbers that you must enter, and if it is hex you are limited to 0 1 2 3 4 5 6 7 8 9 0 A B C D E F.
64bit key is around 5 ACII (normal letters) Or 10 Hex digits
128bit key is around 13 ACII or 26 Hex digits
2 hex digits = 1 ACII letter.
And so on. Generate a high security key for the lenght that you want from
http://www.andrewscompanies.com/tools/wep.asp
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
If it helps, go ahead and click on the 4 thumbs and leave a short comment. As this is the free side of fixya, the comments are the only reward I can get for helping people like you who use the free services.
Posted on Oct 14, 2010
Iphone 4s will not accept password to d-link di-524
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.
Jul 15, 2012 | D-Link AirPlus DI-524 Wireless Router
I forgot my WEP key for my ps3
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Mar 18, 2012 | Linksys Computers & Internet
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
HOW TO SET WIRLESS PASSWORD ??
>first, access your linksys' default gateway by typing 192.168.1.1 on you browser's address bar
>Graphical User Interface (GUI) will be accessed
>Now it will ask you to login by default the Linksys routers uses either "admin" as username and "password" as the password or leave the username blank and type "admin" as password. Not unless you have setup a logon security for your router's configuration. After logging into the router's configuration, go to SECURITY tab, if your wireless connection does ask for a username and password for you to connect then you need to ask your Internet Service Provider (ISP) what type of security is compatible with your service will it be WEP,WEP Shared, WPA2 etc...
Now, if you select WEP the password is plainly a 10-digit code, if it's other than WEP then the wireless password has to be a 16-digit Alpha-Numeric code...
Sep 14, 2010 | Linksys Wireless-G WRT54G Router
How do I obtain my own WEP Key?
Hi Friend,
Please follow the steps:
1.Open router page(192.168.0.1)
2.Enter the username and password.
3.Click Wireless settings.
If you have configure the password you can see it in this section or else you can configure the passwword as mentioned:
Name(SSID)-As per your choice
Region-As per your location
Channel-1
Mode-you can select g only (if u have a G wireless adapter)
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption-64
Security Key
Key1-Type a 10 digit or 10 letters password(like your telephone number)
Click Apply and turn off the router for 30 seconds.
You have a secured network now.
Regards
Chiranjeet
May 23, 2010 | NetGear WGR614 Wireless Router
I need to switch to wep from wpa with 2wire and i cant find out how to i want my ds to work with my wifi
For most models, browse to the 2wire's GUI by typing gateway.2wire.net into the address bar.
1) Click on the homenetwork icon.
2) Click on wireless settings
3) Enter your system password
4) Left hand side under encryption change from WPA to WEP
5) Save.
Mar 02, 2009 | Gateway Wireless-B Router (wbr-100)
IPod connection to Zoom ADSL X65590 router
you have to log in http://10.0.0.2 at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Dec 26, 2008 | Zoom X6 (5590) DSL Modem (55900003)
2wire 2700hg-b modem
if you have posted the correct model, you cannot connect a modem to this router as it has it's own built in modem, so in effect the routers modem will not configure properly, remove your modem and try again as there is no reason why the key code numbers should not work, unless you have caps lock on when you should'nt or visa versa
Nov 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
166 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
