Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
On the sears craftsman 917.273011 mower how do you change from High range to Low range? I inherited this mower and can?t seem to get it to work; I just don?t know the how-to of it
  • 49 Answers
SOURCE: craftsman mower 917 273201
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Posted on Feb 11, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
saailer
  • 1868 Answers
SOURCE: craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Posted on Jul 08, 2010
Testimonial: "Thank you very much!"
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
I recently purchased a Sears 22 self propelled with rear bag
they only catch grass not dirt they need air flow to work and if not porous they wouldn't work
May 31, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
I have a Craftsman 11/36 ride on Mower I inherited. I need a new belt and want to know where I should get one. Who are the distributors? What size is the belt? Include beltdimensions [Width and...
Sears has one convenient location on the web to get all your Craftsman parts. They carry most parts for you tractor for at least 20 years.
You can get a new belt from searspartsdirect.com. You will need the model number off the mower to find and order the part. The number looks like 917.123456.
When you enter the model number into the search box at searsparts diagrams will pop up. You can locate the belts and order right there.
If you can't figure out the diagrams, you can go to any Sears store and they will help you order the part. All Craftsman parts are plus shipping.
Please rate this answer!
Feb 03, 2011 | Craftsman Garden
I inherited a riding lawn mower, Craftsman DLT300 w BriggsStr 18.5 HP OHV. I have never worked on anything mechanical in my life, but my 8 yr old son has a desire for it. So I got this as our project to...
Here's how I would start.
Open the thing up as much as you can.
Get rags & cardboard and clean up the oil, esp. on the engine.
See how to put oil into the engine, add and check the level.
Start the engine and watch. See what the problem is first.
There are parts available at Sears, online, etc.
The repair itself could be somewhat simple and possibly too hard to do, but the first step is to "see" what is the problem.
I have a motor that needs a low oil switch, but it involves opening two halves of the engine, I don't want to do that myself.
Dec 27, 2010 | Garden
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Motion belt slipping craftsman 2000 42" hydrostatic
Irritating problem, Have you checked your rotor heads to insure there free spinning? They could be gummed up and need lubed causing high resistance against the belt.
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We are trying to figure out how to assemble our 42" sears craftsman snow plow.
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of your blade and you will see a parts diagram of it.
Dec 21, 2008 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
142 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
