Question about LG DH30 GoldStar Dehumidifier
Capacitor... discharge it?
Tried the ol' bucket switch, not stuck and seems fine. For a short time I could get the fan to come on, but now can't even get that. What's the easiest way to discharge/test the capacitor? Thanks for your time with this matter, amazing that there is NO service to be found for these dehumidifiers (might just be that it's southern Vermont and have very few humans out here anyway).
Vaughn P.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The easiest way to is to short it out across the two terminals with an insulated screw driver. Then you use your meter to test it. http://www.repairfaq.org/sam/captest.htm#ctsaf
Sgt 48
Posted on Jun 02, 2008
  • Andrew Lauder Jun 04, 2008
    Just looking at the wiring diagram, there is a fuse on the board itself, you would have to replace the board if it was blown as I don't think it is replacable. The part number is 6871A30032B
The "bucket full" light blinks even after the
Eddie, turn the unit OFF & unplug it. Then remove the bucket and check the float valve in the top of the bucket. It may be stuck in the 'UP' position or is broken. When reinstalling the the bucket, be sure that it fit's "squarely" from top to bottom in the bucket holder and is making firm contact with the bucket safety removal switch on the rear wall of the bucket holder.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | LG LHD65EBL Dehumidifier
My WHD928 won't start. Plugged in, tank is in correctly- but no go. The lights don't even come on. Is it terminal??
I hope it's not terminal, as Windchaser is no longer in business. Remove and check the top of the water collection bucket for a float valve. It may be stuck in the "UP" position. If it is, jiggle the arm to make it return to the "Down". While you have the bucket out, look inside the bucket holder. On the rear wall of the holder you should see the bucket removal safety switch. It should look like a plastic trigger switch. With the unit ON, activate the switch with your finger. If the unit does not turn ON, then the switch is at fault. If it turns ON, then the bucket was not making contact with it, when it was last reinstalled. Reinstall the bucket "squarely" from top to bottom into it's holder. Making sure that it does not tilt down at the bottom when installed and makes contact with the switch.
If the unit did not turn On when you tried to activate the Bucket Removal Safety Switch, it's time to start shopping for a new dehumidifier. As there are no parts available for Windchaser units.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 08, 2011 | Windchaser WDH928 Dehumidifier
Fan runs, compressor switch seems to click but fails to start. Compressor is warn to the touch.
The compressor is not starting, either the start components (relay and capacitor) have failed or the compressor is no good.
Here is a tip that I wrote to help people tofigure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 24, 2011 | Kenmore 54501 Dehumidifier
The bucket full light flashes even though its empty and inserted correctly and the humidity level is stuck at 1%. The unit as a whole just seemed to stop working.
I have the exact same problem. I suspect this is the same as the "CH 01" problem others had with a different unit that seemed to be the bucket switch. I still need to confirm.
Nov 21, 2010 | LG LHD65EBL Dehumidifier
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 07, 2009 | LG DH30 GoldStar Dehumidifier
Dry function will not work
There are Five Main reasons that this will happen
4 - Wired wrong
5 Compressor is locked up
Aug 07, 2009 | Danby DDR583R Dehumidifier
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose.
You need an AC outlet of a central AC in your basement, or a window unit if there are windows.
Warm air at discharge is normal.
Sep 04, 2017 | LG LD40E Dehumidifier
Goldstar Dehumidifier model# DH305Y7
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
May 27, 2008 | LG DH30 GoldStar Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
620 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Michael Van Der...
Michael Van Der...
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
