Question about Electrolux Dishwashers
Simpson 960 ESP dishwasher won't go past the prewash
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
My simpson dishwasher doesn't work anymore
Click on link or copy and paste in your browser: http://www.manualowl.com
Apr 13, 2012 | Washing Machines
Kenmore 17373 dihwasher overfills on prewash cycle only. I can turn off the water supply on the prewash, wait for the cycle to complete and drain. Then turn the water back on, and it runs fine for the rest...
it is posible to have a presostat(presure gauge) for prewash and this is damaged(bloked) and another for wash, this may be positioned on a main board or in another place. i don't thick you wil fix this problem whit out the qualified personel. also can beanother problem and for this you must call an specialist.
Feb 14, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
80 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
