Question about kawasaki PVS1965 Portable DVD Player
One of the monitors just stopped working. Do you have any suggestion. I worked the last time we used it. now hooked up in the car and one is dead. Is there a repair place for them. I just think it can't be to bad. It has not been dropped or anything.
  • 998 Answers
Just try to check first the cables or swapped it to the one is working.
Posted on Oct 14, 2010
My laptop Lenovo G-580 has blanked out...not starting. Please help.
Check google for this. Lenovos have a habit of just dropping dead.
If you hit some key combinations it will reset the unit and then work.
If that does not do the trick then you have some serious problem. Hook up another external monitor - if that works then issue is with your built in screen - if external monitor also dead then you have a boot up issue with the mother board. Not good.
Sep 06, 2014 | Computers & Internet
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
Lg flatron monitor L1960Tr stopped working. Last week it turned on very slowly . Now It does not turn on at all
Hook up the monitor to a working desktop computer. If you still don't get video or lights to come on then the Monitor is dead and would need to be replaced. You can also try anotherworking monitor on your desktop to make sure its not an issue with the computer.
Oct 02, 2011 | LG L1960TR 19" LCD Monitor
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
I have a dell Inspiron 8000 that is dead. Was working fine last time used. After pressing the power button The Hd light will flash a few times. There is a few sounds, And you can see a quick bleep in the...
there should be a video output on that laptop. hook it up to an external monitor and use the keyboard combination of keys to toggle on the external monitor and watch to see if you get the same issue
Aug 20, 2010 | Dell Inspiron 8000 Notebook
My laptop's screen is not working properly. Sometimes it stops working for a second, it stays grey, like a bad TV conection. I don't know what to do. It's a HP pavilion dv5-1251nr. Usualy it happens for...
Try hooking it to LCD or external monitor if working then,buy a new LCD with removal instructions on Ebay.
www.ebay.com
If the external doesn't work buy a motherboard on ebay
Oct 03, 2009 | HP Pavilion dv5-1251nr Notebook
Analog Dead/DVI OK
Sounds like the video controller board inside the monitor has blown a transistor. They are only about 3mm wide so not easy to spot even if you look closely.
It's a fairly rare fault, though not unknown to happen without reason.
Nov 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
No Power in Monitor
If you are a tech. Check the voltages going to the Logic Board, if one is missing (12 or 5v. Then that is most likely due a an IC failure on the power supply board. IC 901 Don't quote me on this, but I know it is less than $10. Sorry, I only have 1 left, the last one I did was in Aug2006 so memory is fuzzy. Kegtapper
Sep 08, 2006 | Dell UltraSharp 1800FP 18.1" LCD Flat...
kawasaki PVS1965 Portable DVD Player Logo
77 people viewed this question
Top kawasaki Televison & Video Experts
Robert Roath
Robert Roath
Level 1 Expert
Henry  Thomas
Henry Thomas
wayne chamberlain
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
