Question about Rinnai Toyostove Direct Vent Heater: Laser 56 Toyostove Direct Vent Heater
On l-56 stove an error code EE 8. what is this and can it be repaired?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
The blower motor is not working properly. Turn the stove off and remove the front cover. Remove the lower baffle in the front. Remove the black hose that is about 1 1/2" in dia. If it breaks don't be surprised. Stick a pencil in the hole and spin the fan. Keep trying until it spins freely. If it spins freely from the start the motor is burned. Put the black hose back on and try to start. IF the hose broke you will need a new one. For now put some electrical tape around the break to get you going.
Keep us posted.
Tom
Posted on Oct 14, 2010
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
I have a toyostove laser 56 that blowback exhaust during windy days. Is there an easy fix? Tom
Three times recently I got the EE 2 error. Each time gunk had built up where the tube goes into the firebox. A delicate scraping with a wire solved the problem. Now, what causes the gunk to build up?
Feb 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
CODE ERROR E.EE
When EE:EE is displayed on remote control , press "Energy Save" &
"Zone Control" buttons simultaneously for longer than 3 secs. The error
code will then be displayed on the LCD.Thanks.
Jan 15, 2011 | Fujitsu Heating & Cooling
Toyo stove laser 56 error EE56 what to do
I don't see an error code EE 56 in the service manual. Please verify the error code. What I do see is EE 6. This can be caused by several things. Most commonly a fuel flow problem or out of fuel. If you are out of fuel or the fuel just isn't making the fuel pump, the pump will make a loud ticking or thumping sound. You should check your filter at the oil tank, if you use an external tank. You should also check the strainer in the fuel sump located on the right side of the heater. Two screws hold the cover on. You need to turn off the fuel valve at the tank and have some rags to soak up the kerosene that will come out when you remove the two screws. Take the top off the fuel sump and inspect it also. Kerosene sometimes gels up after sitting a while. The fuel nozzle also gets clogged with carbon from time to time. You can clear this by removing the fuel line from the combustion chamber and inserting a piece of wire into the hole about 2 inches. Another possibilty is a dirty flame rod. You can clean it with some steelwool. Let me know what you find if this doesn't help.
Sep 21, 2010 | Heating & Cooling
I have an error EE 2 on my lazer 56 toyostove Does anyone know what that means?
EE 2 means its not getting fuel, your flame sensor could be dirty, or there could be a problem with the circuit board. The heater goes thru a 3 min warm-up/purge before the pump comes on. If the pump is making a loud ticking sound then it isn't getting fuel. You should then check your filter and the strainer in the fuel sump. If the pump isn't making a noise you could check the flame rod and clean it with some steel wool. You should check to make sure the igniter is working also. After you turn your heater on the cover on the igniter will start to get warm and will get very hot before the purge is done so use caution. Hope this helps.
Apr 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My Laser 30 keeps getting a ee 12 code ans shuts
Ken,
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Tom
Feb 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 56 EE 2 error
Tim,
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
hawkins111@gci.net
Jan 06, 2008 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
227 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
