Question about Graco Baby Gear
Putting up a graco pack N Play and have two short metal rods left over, Where do they go
I know this question was asked a while ago, Go to Lowes or Home Depot and cut wooden dowels or metal rods to fit size. Then use tape and wrap around ends. Not masking tape but The Silver tape (I'm drawing a blank). Hope this helps, it is a quick fix until you can find the real ones.
Posted on Apr 30, 2012
  • 32 Answers
Does this unit have a bassinet that fits on top? These may be the rods for the bassinet.
Posted on Oct 15, 2010
Safety 1st parts
Go to the Graco website Gracobaby.com. Click on the help center button and a drop down will come then click in the replacement parts. It will ask for the model number and date of maunfacter date. This will be found on the the pack n play it's usually on the bottom enter the information. The site will direct you to your model and the parts plus price.
Mar 02, 2013 | Graco Pack N Play Portable Playard Winnie...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How to break down the pack-play for storeage
First, you would have to remove any secondary pieces like bassinet, mobile, change table, mattress, etc.
Next, pull up on both sets of long side bars...and do the same with the two short side bars.
If you have done this correctly, the play pen becomes a cylindrical set of poles that can be stored in the Graco carrying bag.
Nov 02, 2009 | Graco Pack 'n Play
DIRECTIONS FOR GRACO PACK 'N' PLAY
pull and turn the center of it then try to open the side lock. they have to be horisontal from both side of each
Good luck
Sep 09, 2009 | Graco Pack 'n Play
Problems re opening the Graco Pack N Play
you have to pop the sides up before you push the bottom down. when you first start to put it up let the sides fall but keep the middle up. then grab the middle of sides, either length wise or width, one in right hand, opposite side in left hand and snap up. then do the same with the other two sides....then spread out four corners and press down on the center. if you let the center down at all first, the sides will never lock. Also check your lot # there was a recall on some of them
Mar 13, 2009 | Graco Pack 'n Play
Graco pack n play
I know this question was asked last year, but I thought I'd answer for those having this come up on a Google search. I was missing the Bars that go to the bassinet part of my pack n play, as well as the changing table attachment. I called Graco to order replacement parts. They looked up my Model and Serial number for me. They stated they had the metal bars, but not the changing table attachment. My Pack n play was purchased brand new in 2008. Here is thier number 800-345-4109
Mar 11, 2009 | Baby Gear
Need to know how to put the pack & play together, Lost the directions
Graco Pack 'n Play 9999SOU In Scout
Playards
You've Come to the Right Place
Download instruction manual from;
http://www.gracobaby.com/Instruction%20Manuals/ISPP067AA.pdf
Mar 04, 2009 | Graco Pack 'n Play
Baby Gear Logo
705 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
