Question about Sage Instant Accounts 8.0 (013604ug)
When trying to remove/delete a supplier, which we do not use any more Sage gives a message "Not all of the records selected were able to be deleted" "POSSIBLE REASONS: 1.Balance remaining on account 2. Transactions still associated with accounts." there is no balance left on this account, but still unable to remove.
SOURCE: error message with sage instant accounts
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
Posted on Apr 17, 2009
  • 28 Answers
SOURCE: wrong date on sage accounts plus
go to settings and financial year click on change button and change year.
Posted on May 07, 2009
SOURCE: Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Posted on Aug 27, 2009
  • 28 Answers
SOURCE: I have been using Sage Instant Account for 4
If sage doesn't prompt you to clear the user you can manually delete the queue.dta file from your data directory
Posted on Jan 04, 2010
SOURCE: Sage Instant Accounts error Message Coming up during Installation
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Posted on Apr 21, 2010
I was working in sage instant accounts version 8.2 when my computer crashed. Im trying to go back into sage but it comes up with the message 'you may only run one copy of this programme at any...
May 19, 2011 | Sage Instant Accounts 8.0 (013604ug)
While trying to save parts of a TV-programma I recorded on mij Panasonic DMR EH50 DVD-recorder I try to delete the parts that are'nt useful to me. The recorder gives the following message: Can not 'work'...
Highlight the recorded program on Direct Navigator then press the Sub Menu button on the remote, then select "Shorten Title". Press (Enter) at the start point and end point of the section you want to erase, then use the up/down button to select "Next". Then, select "Erase" to delete the unwanted sections. Repeat this process for all unwanted parts, then select "Exit" to return to Direct Navigator.
Nov 01, 2010 | Panasonic DMR-EH50 DVD Recorder
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Deleting recordings off sony icd-mx20
Display the folder o message in the folder that you want to erase.
Press Menu and select Erase by using up arrow down arrow and then press play stop button, the cursor moves to erase menu.
Press up arrow down arrows to select erases all the messages or message in a folder.
Press up or down arrow to confirm say yes and press play
Press stop to exit.
Mar 31, 2009 | Sony ICD-MX20 Digital Voice Recorder
Error message with sage instant accounts
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
MY SONY ICD-ST10 RECORDER IS STUCK WITH AN "ERR ACCESS" MESSAGE
I try this solution but it didn't work! I can select WHOLE but I can't select DELETE from the menu.
How can I do for restore the data storage or for delete all and formate the IC recorder?
Dec 10, 2008 | Sony ICD-P210 Digital Voice Recorder
Sony ICD-P210, ERR ACCESS message
Your problem may have been caused when you removed the unit from the PC without using the "safely remove hardware" option.
What you need to do is download the latest version of Digital Voice Editor (I think we are up to 3.1 now)
When you connect the ICD unit it will probably give you a number of access errors
Ignore them and go to the IC Recorder Menu. Select WHOLE and DELETE. Delete everything.
After a minute or so the unit will come to life and you'll see the Directories that are standard in your unit.
Remove the hardware from the computer (safely! by closing the program first) and turn the unit off.
Now turn it on...... Bingo!
Apr 01, 2008 | Sony ICD-P210 Digital Voice Recorder
Username
When i have this problem I go into the sage programe via programe files, click into ACCDATA, look for the file named que and delete it. Works every time for me.
Nov 08, 2007 | Sage Instant Accounts 8.0 (013604ug)
Computers & Internet Logo
60 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
