Question about GE PSC23SGRSS Side by Side Refrigerator
I have GE PSC25PSWA SS refrigerator evaporator in refrigerator side is freezing
  • 5 Answers
SOURCE: ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
SOURCE: GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Posted on Jan 16, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
SOURCE: GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Posted on Jun 13, 2009
aasc
  • 1606 Answers
SOURCE: My GE SS Side by Side Refrigerator is not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Posted on Dec 16, 2009
Hi. Our GE GSH25JSDD SS side by side drive just stopped freezing, cooling. The fan is on inside freezer and lights, and motor down on bottom, back is running. Drain is clear. Won't cool down.
I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Board is the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Ge refrigerator side by side , PSS26LRE SS, does not cool After manual defrost, it will work for several days and repeat again. Refrigerator bottom draw freeze everything. Please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top of refrigerator is warm and bottom freezes everything it is a side by side refrigerator and the top two shelves of the freezer(along with the icemaker) thaw and melt but the bottom freezes and the top...
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Feb 07, 2010 | Refrigerators
GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
May 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSC23SGRSS Side by Side Refrigerator Logo
307 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
