Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Refrigerator does not get cold. stays arount 57 degrees. KitchenAid model KSRU25FKWH01 Freezer works. Cleaned condenser coils, coils in freezer are not frozen. Think the circulation fan is not working. Is it located in the upper left side of refrigerator
eagle338
  • 4889 Answers
SOURCE: kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Oct 19, 2007
My email is bb_hm@hotmail.com. Thanks for your help!
Posted on Aug 24, 2008
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
  • 66 Answers
SOURCE: Clogged or frozen condensate drain.
The rear panel inside of the freezer should have screws in the corners. Remove these screws. You can remove the back panel and the evaporator coil and drain should be accessable now. Do not force the panel out. You should be able to remove it fairly easy if it isn`t iced up badly.. If you have any other quistions, please ask. I will help you as much as I can.
Posted on Nov 10, 2008
tborn6
  • 700 Answers
SOURCE: refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Posted on Dec 26, 2008
We are experiencing a heat wave. My new Kitchenaid fridge does not seem to be cold enough, and the items in the freezer area are not freezing. I have turned the temperature for the freezer down to -4...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | KitchenAid Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
My Samsung side by side freezer temperature has gone up to 57 degrees. The refrigerator still works at 38 degrees.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 11, 2011 | Refrigerators
I have a Kitchen-Aid refrigerator in my garage that is about 15 years old. Food in the top has been thawing some and the bottom stays frozen. I put a thermostat in the freezer and it seems to vary from...
Refrigerator
heatman101
Jan 23, 2011 | KitchenAid Refrigerators
Cleaned the condenser on my kitchenaid superba model kscs25Inssoo, but freezer is still making a loud humming sound. What could it be?
Refrigerator
heatman101
Jan 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
Fridge at 57 and freezer on 27 alarm keeps coming on
Refrigerator
heatman101
Dec 30, 2010 | KitchenAid Architect KBRA20EMSS Bottom...
Our KitchenAid Refrigerator Model KTRS22EM is not freezing or cold enough in refrigerator Indicators are all at maxium , cleaned coils and you can hear it go on but not getting cold.
heatman101
Sep 01, 2010 | KitchenAid KTRS22EM Top Freezer...
Freezer not cold 50 degrees and rising
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
34qgarhsg
May 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
