Question about Whirlpool Refrigerators
Side-by-side fridge is freezing food on bottom shelf
  • 828 Answers
Look to the freezer section for a possible frosting on the back wall. If you have a defrost problem in the freezer and air circulation stops cold air from the freezer may settle through the return area of the duct between the refrigerator and freezer section because cold air is heavier the warm air. Normal circulation follows a clockwise pattern.
Also your setting of the refrigerator temperature may be set to cold. Once again cold air settles to the bottom.
Posted on Jun 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
milten1
  • 1304 Answers
SOURCE: fan was making a funny noise inside the freezer
migration due to a bad fan
look up the model number at sears
a new fan will fun 25-60 bucks
Posted on Oct 03, 2009
heatman101
  • 43501 Answers
SOURCE: HI....My Fridge only cools down in the bottom part of it.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 18, 2010
Sea Breeze
  • 4655 Answers
SOURCE: MFD2560HEW Bottom freezer french doors. Top shelf
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Posted on Jun 03, 2010
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
Refrigerator food freezing even when on lowest setting
There is one of three reasons why your fridge section is freezing food. You didnt mention whether you had a side by side or freezer on top or bottom model, so the following checks may not apply to your unit.
One reason food might be freezing is your cold control has failed, and will not turn the unit off when the physical temps are correct. When this occurrs food normally freezes throughout fridge section, top, bottom, middle, front and back.
BOTH controls, though you may only have one, should be at the middle setting. Adjust your controls, place a plastic cup of water at the top, the middle, and bottom shelf of your fridge. Check all three AFTER 24 hours. if all three are ice, you COULD have a bad cold control.
It is possible you might also have a door damper that is stuck open. A door damper is a swinging or sliding door that opens / closes either when temp control settings are adjusted, or on some fridges, when either door is opened, the damper closes. Please note, door dampers are USUALLY only present on side by side refrigerators. They can have a motor, or thermostat open the door automatically,which can break, and others will simply have a lever of some sort, which usually wont.
If after 24 hours, only the middle and bottom cups are ice, your evaporator fan motor, in the freezer, is likely not operating. Not knowing the BRAND you own, it could be the motor itself, a thermostat located on the evaporator, your defrost heater, or a main computer control board that controls the fan motor.
Sorry I cant be as specific as id like, but i had to cover all possible bases
Oct 16, 2011 | GE HSM25GFTSA Side by Side Refrigerator
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Jan 28, 2011 | Amana ARB190RCB Bottom Freezer...
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 22, 2011 | Refrigerators
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Fridge is freezing food on upper shelves
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Sep 05, 2017 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
168 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
