Question about Vacuums
EWave Microwave model # KOT-151S---Keypad only works occasionally. Seems as though it is not getting a good connection. Sometimes, if we hit the side of the keypad it will work.
2 Suggested Answers
  • 79 Answers
SOURCE: Microwave appears as though it
Hi. Microwaves are not the kind of thing you want to work on yourself, and one that is malfunctioning can be dangerous to those near by. If the warranty is up your best bet is to recycle it and get a new one.
Posted on Sep 09, 2011
Where can I get a diagram of the inside of a Shark Steam Mop, Model S3901
Unless you\'ve been using distilled water in this unit, it will be collecting a sort of scale layer of calcium, lime, etc, on the interior walls of the steam chamber. When you clean the unit, with a cleaner of your choice, you will get a lot of this stuff off and out when you drain, but frequently there will be a few small chips that will decide to break loose after the main loosening and draining. Sometimes one or more of these errant chips of scale will find it\'s way to the heat channel of the unit and won\'t let the heat out, even though you just cleaned it. If you have or can find, one of the large paper clips, bend one of the tangs out straight and use it to sort of bore out the holes in the bottom, this will sometimes help tremendously. Occasionally, a second dousing of the same treatment is in order, to pick up those last little left over pieces.
Apr 28, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Height adjustment not working.
It's likely the circuit board that controls the height adjustment motor, or the motor itself. Your local sebo service center will be better able to test to see just what is wrong. Though it wouldn't hurt to take a look at the boards sometimes they're visibly burnt, or connections can be loose. Good Luck!
Feb 16, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Handle on linx is bending off
I've seen them come in with that, I've seen it fixed with tape more often than anything. Low tech, low cost. Not professional in any sense of the word but it seems to work.
Good Luck
The Vac Dr
Jan 07, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
Philips 707/05 Portable DVD Player charging issue.
Just go out and get a new charger to replace the one with defective wire/plug.
Aug 31, 2017 | Philips Vacuums
Microwave appears as though it is working, however only heating sporadically... sometimes does not heat at all.. others heats well.. seems to be hit and miss. It is only 2 years old and everything else...
Sep 09, 2011 | Vacuums
Whirlpool microwave wont shut off when the door is closed or after pushing off
I have an Ewave microwave that just did a number of crazy things on it's own. I unplugged it and it reset everything. It has been fine ever since. Give that a try!
Sep 05, 2011 | Vacuums
Ge Microwave stopped cooking, lights inside went out and the keypad doesn't lite
Check to make sure that a circuit breaker hasn't been tripped in your breaker box. If that's not the case, you can pull the microwave out and check the back for a fuse. Generally fuse access is located next to where the power cord enters the device.
Jun 01, 2011 | Vacuums
We have been given a super showerwave microwave and need an instruction manual can I get this on line?
First try http://kitchen.manualsonline.com , but you'll need the model number.
Also try calling Sanyo Fisher service. Sometimes they offer it for free.
800-421-5013
Monday - Friday, 7:30AM - 5:00PM PST
Sep 26, 2010 | Vacuums
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need drive belt
I'm guessing you have a hoover self propel windtunnel. If that is the case then you should bought the V belt suffix 034 and Flat belt suffix 035. The belt numbers should be listed on the serial tag though.
With most hoover two belt systems there is a pulley that is supposed engage when you recline the machine and this will apply tension to the V belt and tighten the system up so that the brush will spin. If you hold it upside down with the bottom plate off, and release the foot pedal, you should be able to see it happen.
Occasionally that pulley gets stuck and on some newer models they are prone to breaking as well.
Make sure the machine isn't set to floors.
Good Luck
Nov 25, 2008 | Hoover Vacuums
Vacuums Logo
192 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
