Question about Cameras
The screen on my kodak easyshare c643 is really dark and faded and cant make out what is on the screen it is the same when the kodak sign comes when you turn the camera any help would be appreciated
  • 7 Answers
SOURCE: Kodak EasyShare C643 - broken display
Call up Kodak at 1-800-431-7278 select option 3 and they gave me a price for my C743 of $44.35 + $15.00 shipping, but still no luck on the internet but cheaper than a new camera.
Posted on Feb 08, 2008
SOURCE: Kodak EasyShare C643 digital camra LCD screen cracked
I DID IT FOR FREE, AND NOTE THROUGH THE SCAM THAT YOU ALL RUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Apr 02, 2009
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Posted on Jun 08, 2009
  • 942 Answers
SOURCE: Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Posted on Jul 06, 2009
BillB-SA
  • 2761 Answers
SOURCE: kodak easyshare c643 - batteries are fresh, but it
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Dec 20, 2009
Testimonial: "Thanks for the help!"
How do I format a 4MB SDHC card for this camera
"SD and MMC flash memory cards marketed by Kodak, Kingston, Sandisk, PNY and other flash-memory card manufacturers will work with the EasyShare C643. The digital camera supports standard MMC cards and SD (secure digital) cards, but not SD High-Capacity (SDHC) or SD Extended Capacity (SDXC) cards."
Read more: Compatible SD and MMC Cards for a Kodak EasyShare C643 ' eHow.com http://www.ehow.com/facts_7590028_compatible-cards-kodak-easyshare-c643.html#ixzz1BijGdWKF
Jan 21, 2011 | Kodak EasyShare C643 Digital Camera
Kodak C643 dark pictures
Change to a higher ISO sensitivity setting. It is probably on 80. Change to the highest setting which is probably 400. If you can get much higher, like 1600, then try that.
If you use the flash, it may be better to not use it... try a few pix with & without the flash (after you set the ISO to the highest setting).
Next camera, get one that will go to 1600 or 3200 ISO.
Hope this helps!
Sep 08, 2009 | Kodak EasyShare C643 Digital Camera
Image screen on camera has large black spot on it
yes go to like a camera store a get a replacement to be installed and by the way your led screen is broke
May 26, 2009 | Kodak EasyShare C643 Digital Camera
Apr 01, 2009 | Kodak EasyShare C643 Digital Camera
Kodak EasyShare 643
theres a setting somewhere on it to where you can change the brightness of the screen. the lcd on mine doesnt work so i couldnt tell you how to get to it. hopefully, the lcd isnt cracked.
Aug 30, 2008 | Kodak EasyShare C643 Digital Camera
Kodak C643 Screen
Jan 13, 2008 | Kodak EasyShare C643 Digital Camera
C643 error on screen
I had the same problem with my C643 I took it apart and still found nothing wrong. I didn't feel like paying kodak prices so I just sold it on ebay so someone could get it for the high demand LCD screen.
Dec 28, 2007 | Kodak EasyShare C643 Digital Camera
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Cameras Logo
15 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
