Question about HP Compaq Presario CQ50-107NR Notebook
I have a compaq cq50 and my dog jumped on the screen breaking the hinge I replace the stripped out screw so the screen was fine. but a day or two after the screen broke it would just shut down randomly. it would just shut off no normal shut down procedures. my intentetions was to install xp, so I started the process by booting from disk and it will shut down before the file copy is done. the fan is clear and working. my first thought was a heat issue
askmenow
  • 22 Answers
SOURCE: Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
Posted on May 19, 2008
SOURCE: HP Compaq nc6400 does not boot
i missed recovery cd fot HP Compaq nc6400
Posted on Jun 10, 2008
  • 221 Answers
SOURCE: I?m facing a problem with built-in microphone that its not working after i install XP.
Try going to the control panel,
  1. click on sound's and audio device's,
  2. in the sound's and audio device's propertie's box click the voice tab at the top,
  3. under voice recording check to see if the internal mic is checked in the voice recording, default device box,
  4. if it is click the volume box, a new box will appear that say's recording control,
  5. make sure the microphone has a check in the box,
  6. under microphone click the advanced tab,
  7. in the advanced tab make sure the microphone boost has a check in the box,
  8. go back to the sound's and audio device's propertie's box under the voice tab,
  9. at the bottom of the box under voice click on test hardware,
  10. on some built in microphone's you have to talk into the area where the mic is located on the laptop.
  11. if it does'nt help try using the device manager to resolve the sound issue's, check to see if the device is enabled, if it is use the troubleshooting tab to see if the device has a conflict, if it's working properly it will say this device is working properly, or try using the update driver tab.
Posted on Apr 16, 2009
steveparlin
  • 61 Answers
SOURCE: compaq presario cq50-100em wont start up
I'm sorry to say this sounds like a system board failure. On my HP DV200t, a very similiar issue occured, eventually only the led where you plug in the power cord would turn blue. I replaced the system board and all the issues went away.
Hope this helps, and I am sorry to be the bearer of bad news.
Posted on Aug 31, 2009
murmerjoy
  • 805 Answers
SOURCE: HP dv6910 worked fine yesterday; today it will not
you can format your operation system. and in boot drive if you have not sufficient space i mean minimum 20 gb then your pc performance become better before.thanks
Posted on Feb 24, 2010
It looks like the hinge assembly has cracked on one side - solutions anyone?
Here is where to order a new hinge
http://lcd-hinge.ecrater.com/p/13973872/compaq-presario-cq50-110us-hinge
Sep 11, 2012 | HP Compaq Presario CQ50-110US Laptop
Tip
How fix cabinet hinges quick and easy.
If you've ever had a kitchen cabinet door hinge fall off or get loose due to a wood screw stripping out. This can be fixed very easily with a golf tee or toothpicks. Just remove stripped screw and expose screw hole. Put golf tee or toothpicks in hole and break off even with surface. Now just replace screw in the original location and the toothpicks or tee will tighten up screw like new.
on Oct 10, 2010 | Home Fencing
Compaq Presario CQ50 notebook screen goes fuzzy when opened to a certain angle (about 90 degrees). Wires being pinched at the hinges? If so how do I go about repairing this?
it sounds like you've damaged the cable that goes from your graphincs card to your screen or when you move it to 90degrees it's disconnecting. it's usually caused by someone opening the laptop and not putting the cable back in the right place, or loose screws in your hinges or a broke hinge. there are plently of videos showing how to open it up. follow one of them and make sure your wires are sitting in the right place, you don't have loose screws and the hinges aren't broken.
Jan 13, 2011 | HP Compaq Presario CQ50-110US Laptop
My cq50-211nr laptop was accidentally dropped and has a crack.
Ordering the part and replacing it yourself may be just a tad cheaper, but at a risk, may break new screen or cause problems with more parts, I would take it to HP, then again, an LCD screen replacement costs about the same as a new compuer. It's really up to you.
Good Luck ;)
Apr 06, 2010 | HP Compaq Presario CQ50-211NR Notebook
Can anyone tell me why a keyboard on the CQ50 would stop working after opening the case? I replaced the display in my CQ50, something I have done several times before with other laptops. When i...
Are you sure that you have inserted the strip connector correctly into the motherboard connector? If not fully inserted before closing the pressure clips it may not connect properly.
Mar 19, 2010 | HP Compaq Presario CQ50-110US Laptop
How can i put a keyboard in my laptop?
the piece of plastic above the key board is held in by clips,,it will unsnap..be very gental or it will break..after the top plastic is off youll see 3 screws holding the key board down,,there usally very small phillips head screws..then after the screws are out gentally lift the top of ther keyboard up..under that there will be a plastic wire strip..it will in clip at the mother board end..dont break the clip..and there is proolly 2 or 3 wires that go to your touch pad mouse...tehn just lift the key board out and follow these directions in reverse order to install the new one..
Nov 10, 2009 | Compaq Presario CQ50-215NR Notebook
Screen shakes
i just tap the top of my screen and it stops
Jan 29, 2009 | Compaq Presario Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
HP Compaq Presario CQ50-107NR Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
