I tried to print . A window said to replace the wellow cartridge. The printer is only 1 or 2 months old and not used much.I took it out and put it back- no change.
    Genius:
  • 2,785 Answers
Have u install new cartridge
Posted on Jun 02, 2008
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
Printer says Ink system has failed.One of the cartridges was missing for one month and since I replaced it this message shows.I did all as per HP support and is still not working.
sounds like the printing heads are clogged. try taking old cartridge and putting rubbing alchohol in it and try several times to print test page. you can also use q-tip to clean the area where the cartridge ink connects to cartridge holder.
Nov 04, 2010 | Office Equipment & Supplies
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
HP 6310 printer says HP 95 tricolor is empty.
Ray,
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
May 16, 2009 | HP Genuine HP 95 Tri-color Inkjet Print...
HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Sep 10, 2008 | HP Business Inkjet 1100dtn Printer
Very light printing
Call Kodak and tell them you're problems. I was in same boat with new cartridges and still problems. My printer was only 9 month old and printed over 600 pages. I received my new printhead along with brand new cartridges and sample of 4x6 photo paper. However, having problems removing the printhead. New printhead came within 1 business day of calling Kodak!
Sep 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
37 people viewed this question
jasbo
jasbo
