Question about Heritage Pool and Cover Pump
Pump turns off after 5 to 10 seconds? - Heritage Pool and Cover Pump
  • 990 Answers
This could be the pump has gone bad, or just a stuck or clogged impeller. You need to remove the bottom and check that the impeller is clear and be sure it spins freely. If you can spin it and it stops when you plug it in then the motor has gone bad, or if it just won't start when the impeller is clear, or it just won't turn at all. Then it is time for a new one. If you find something holding the impeller from turning remove it and your probably good to go.
Posted on Oct 14, 2010
I wanna know how to change a fuse for a saturn aura 2007.
What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
Feb 02, 2017 | Saturn Cars & Trucks
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Fuel being being pumped out off r/h air filter for a few seconds, does it when trying to start as well!
it's normal for it to run for 5-10 seconds if you turn the key but do not start the car it will shut off.
Apr 15, 2013 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
Tv works fine,cut it off and it will not come back on . Red light blinks 6 times, then repeats itself.
this is an indication of a overcurrent/ overvoltage error....meaning short in a voltage supply. I have seen this problem in the shop with this set. IN MY CASE it was shorted convergence chips. but it could also be any of the low voltage supplies 5,10 15,-15 lines
Oct 16, 2010 | Sony KP-53HS30 53" Rear Projection...
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Rust on the lid
You will need to use steel wool to lightly scour off all rust, Then you should use an enamel paint or clear fingernail polish to repaint the area.
Oct 11, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
1996 cheve lumina . gas pump, when I turn the key
When the key is turned to ignition there is a "Prime" mode that the computer rnus. the pump will only run for a few short seconds. If you crank the engine you should get power to fuel pump the entire time you crank the engine.
Oct 09, 2009 | 1996 Chevrolet Lumina Mini
Back light will not come back on.
if your on the back light settings, then press the down arrow three times. if your not, you can tilt it in a certain way so that you can kinda see what your doing
Feb 17, 2008 | Motorola Mobility TracFone® V170 Cellular...
Viper MSNV-939 ATX Socket 939 audio connector jumper settings
 u short the pins with jumpers as per the diag
        5    4     3    2    1
       10          8     7    6
in this u short the   5,10  with one jumper &   3,8 wth another jumper
was this helpful to u, give the rating for me
thanks
Oct 15, 2007 | Mach Speed (S755) Motherboard
Heritage Pool and Cover Pump Logo
120 people viewed this question
Top Heritage Pool & Spa Experts
john h
ray gallant
Mike Raino
Level 1 Expert
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
