Question about Canon Cameras
How do i get a clear shot of an object with a blur effect on the background with my canon powershot s90? if i am at the custom setting,... how do i get it programmed???
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You're seeking what's called a "narrow depth of field." Depth of field is controlled by three factors: focal length of the lens, the lens aperture (f/stop), and distance from the camera to the subject.
The longer the lens, the narrower the depth of field, The larger the aperture, the narrower the depth of field. The closer the distance, the narrower the depth of field.
Unfortunately, the lens on the S90 is a 6-22.5mm zoom, and a lens that short is going to give you a rather wide depth of field in all cases except extreme closeups.
Here are some things you can TRY to get the desired effect:
Set the camera to the sports or portrait mode to get it to try to reduce the depth of field.
Put as much distance between the subject and the background as possible.
Get as close to the subject as possible.
Zoom in as much as possible. (I know this conflicts with the previous one.)
Posted on Oct 14, 2010
Our Canon Power shot A95 is used to take close up photos of jewellery ,with a white background.We have been useing the TV mode with the MF to focus.Howerev the pictures are over enposed, what can we do to...
Instead of shutter priority "Tv" mode, try setting to program "P" mode instead. Also, turn off the flash, and set to macro if shooting close-in (press downward on the little flower icon on the back disk). If pictures come out blurry, try using a tripod to hold the camera steady, or set the camera down on an object so it doesn't move while taking the shot. Try using the timer to activate the shutter to allow the camera to remain even steadier for the shot.
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
Hallo, my canon powershot A420 camera shows horizontal white lines in LCD screen mostly in night shots and the day light shots appear blurred as if more light is entering and the image is not clear.
I am afraid this seems to be a hardware error in the sensor. If the image is purplish in color when blurred it is similar to my and another user's problem. He/she contacted the manufacturer and they said they can fix it for $250. I am not a repair specialist so there may be a simpler cause and solution- good luck.
Dec 03, 2010 | Canon PowerShot A420 Digital Camera
When I look through my lens, the object is totally out of focus no matter what I do. The object looks blurry and color is grayish/brownish. What could be causing this?
You do not say if the pictures you take come out blurred?
I believe this powershot model (depends on the precise model/variant) has an optical adjustment just by the side of the viewfinder (small lever or knob). Try adjusting this to bring your view back into focus.
Check you have not set any special effects on eg soft focus portrait and sepia - probably safer to do a camera reset - see your instruction book.
Good luck
Sep 07, 2010 | Canon PowerShot S1 IS Digital Camera
Focusing
You'll have to set the aperture to a higher number. Set camera to Aperture Priority mode and increase the number (usually set at 2.8). The higher numbers will preserve foreground and background focus but will require more light - not a problem in outdoor daytime but at night or indoors will need flash.
Jun 17, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon Powershot S5IS Aperture
Hey Kate
I have owned a Canon Powershot S5 since launch last year and I take a lot of photos with blurred background. I select AV on the dial (Aperture priority) and set aperture to between 2.7 and about 4.0 max, depending on how much depth of field I want and what my subject is.
This setting blurs the background beautifully.. Just remember that an aperture of 2.7 will give you a very shallow depth-of-field, so if focus on face is important, make sure you have face recognition set to ON.
I hope this helps
Apr 04, 2008 | Canon PowerShot S5 IS Digital Camera
Digital slr camera
You'll need to use your camera in manual mode.
If you want the subject sharp, but the background blurred, use a large aperture and high speed exposure. This will reduce the focal length.
Remember that a large apertures are often used for night shots because they allow more light through the lense. A fast exposure will prevent the shot from being over exposed if you are taking it in daylight.
Flash photography is not recommended for the effect you are after.
Mar 24, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon sd 550 (and sd 200) shutter speed
If you check out a review site such as www.steves digi cams. com or even the Canon site to check out the spec of the camera to discover what shutter speeds are available. When shooting fast moving subjects try panning the camera on the object as you press the release this will[to a degree] keep the primary image sharp[ish] whilst blurring the background
Feb 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Blurred purple image
The doe problem go away if you bang on the side of the camera? there is a known issue with the CCD sensor on certin model cameras that after a few years the glue or somthing dries up inside the sensor and it developes a bad connection. Canon has admit they know about this problem and they will fix them free of charge and pay shipping both ways. Sometimes users can bang on the side of the camera and the camera will work properly again but not for very long. I cant see your display so im not sure if thats it or not but the problem has this purple blackish symptom. Go to the canon usa webpage and then search around for your camera model and if there is a known issue it will say on their site. Then there are ways to contact them on their site.
Nov 14, 2005 | Canon PowerShot S1 IS Digital Camera
Cameras Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
