Question about Minolta Dimage Scan Elite 5400 Film Scanner
Just bought a used Minolta 5400 II. Supposedly works fine according to seller. I have this setup on my Macbook Pro Core 2 Duo running OS X 10.5.8. The scanner will not produce any image on a scan/preview attempt. All I get is a blank white frame when trying to scan a negative - or a blank black frame when trying to scan a positive. The scanner seems to be mechanically ok - film carrier moves thru & ejects from scanner fine. I even see the LED light flashing inside the unit. I do not get any error messages - it simply will not produce an image. I have tried the most current versions of Minolta Dimage, Silverfast Ai Studio 6.6.2.r3, and also Vuescan 8.5 - all with the same results. Please help!
Unless you solve this problem, would you think of selling the scanner i need parts to fix mine
Posted on Apr 26, 2011
Factory reset button on macbook pro
There is no 'Factory Reset' button as such. If you are running OS 10.7 to 10.10, then you need to start up from the 'recovery' partition (CMD+R) on startup. You will then be able to erase the hard drive using 'Disk Utility' and then re-install the OS.
Mar 06, 2015 | Apple MacBook Pro Laptop Computer with...
CAN I UPGRADE TO MAVERICKS ON APPLE MACBOOK 2007 LAPTOP
Yes anything with a core 2 duo should work. The only requirement that I'm aware of is 64bit processor and Core 2 Duo is just that. Now if it was a Core Duo (or Core Solo) this would not work.
Sep 20, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
Nov 23, 2009 | Apple MacBook Pro Laptop Computer with...
1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
Cant print to a Phaser 7750 from Snow Leopard 10.6
What a worthless site, you got the question but never an answer
Nov 04, 2009 | Apple MacBook Pro Laptop Computer with...
MacBook Pro 15'' RAM Problems
The earliest MacBook (Pro) models have a limit of 2 GB. To check the specific model, in the Apple menu select about this Mac. Then press more info... . Look at the line like "Model Identifier: MacBook5,2" for my white early 2009 MacBook. If the numbers are 1,1 then for sure you have the oldest model and are memory limited to 2 GB, as the sum of both cards.
That's just like my wife's, it was a Core Duo and not the current Core 2 Duo. Works fine. I was ready to up its memory but read about this in the Apple Support Forum. It came originally with 1 stick of 512 MB, IIRC. I upgraded it to 2x1 GB for a lot more than the 2x2 GB in the newer. BTW some of the Macs between these only take 3 GB but will work with 2x2 GB just throwing 1 GB away. -Ken
Jul 26, 2009 | Computers & Internet
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
Aug 02, 2008 | Minolta Dimage Scan Elite 5400 Film...
Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9.  What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them.  After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
Nov 15, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Dimage Scan Elite 5400 Film Scanner Logo
215 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
